You should check different ROS versions with those modem (old ones and recent ones). Each release (or even within beta series) are each pretty much different and one or two selected versions may still work for you - I have messed with similar issues for a long time already (but different GSM modem brand). Also, you may get some help from sending in a supout.rif to Mikrotik support.
You have K2_0_7_… firmware. It works 100% without removing the resistor. We use MC8790, MC8792V and lots of other manufacturers with RB411U and RB411UAHR.
One more stupid question…did you attach the antenna?
As I was saying
this is the replay I got from Mikrotik support about this R
on the newer 411U has pin22 connected to the minipcie slot. If your
sierra card doesn’t like it, you can remove the resistor which is
loaded. Here is the
where you could see where to look for a resistor:
