I read all wiki and forum, but dont see away to invoice and disconnect users automatically
users are monthly subscribers with unlimited access, the problem is they are billed the day they installed, so users have a different billing days in a month.
wiki automaticbilling goes to the monthend and usage based.
present system config v3.20 -
users are assigned static IP with simple queues, closed Lan access
and hotspot is only used to send users disconnect notice manually
Is there a way using Mikrotik, to check the date the user monthly subscription is due and send them an invoice before due date, and disconnect on pass due automatically. The admin only need to enter manually when they pay to aviod the automatic disconnection?
as i mention automaticbilling from wiki will not work, bec that goes at the end of the month, look for something that check for billing each day, bec customers are not pro rated but are bill on the day they install each month, e.g. 17th Nov to 17th Dec will be a typical billing period
