MPLS/LDP neighbour issue
Hi All,
I have two RB1000s that will not establish LDP via OSPF. In the debug logging i get no messages to show that it even tries to establish an LDP neighbourship.
The config should work as each of the routers has working LDP neighbours.
L2 MTU is not an issue as the working LDP neighbours traverse virtually the same L2 network except one link (Ubiquiti AirFiber).
I have requested support from MikroTik but require to upgrade to latest ROS image which will occur over night.
[admin@RB1000_1] > mpls ldp p
                       enabled: yes
                        lsr-id: x.x.x.x
             transport-address: x.x.x.x
             path-vector-limit: 255
                     hop-limit: 255
                   loop-detect: no
             use-explicit-null: no
  distribute-for-default-route: no
[admin@RB1000_1] > mpls interface p
Flags: X - disabled, * - default
 #    INTERFACE                                                        MPLS-MTU
 0  * all        1508
[admin@RB1000_1] > mpls ldp interface p
 #   INTERFACE                        HELLO-INTERVAL       HOLD-TIME
 0   ether1-vlan37                    5s                   15s
 1   ether1.vlan31                    5s                   15s
[admin@RB1000_2] > mpls ldp p
                       enabled: yes
                        lsr-id: y.y.y.y
             transport-address: y.y.y.y
                     hop-limit: 255
                   loop-detect: no
[admin@RB1000_2] > mpls ldp int p
 0   ether1-vlan32        5s                   15s
 1   ether1-vlan34        5s                   15s
 2   ether1-vlan31        5s                   15s
[admin@RB1000_2] > mpls in p
 0  * all        1508
