MPLS/VPLS ECMP
Good day,
I’m busy experimenting to transport pppoe over mpls/vpls
Now the issue i’m experiencing is we are using at least 2 microwave links to our main towers because the require from 600-1.2bgps.
As soon as MPLS is enabled between the two sites the traffic starts flowing only over 1 link.
Any way to get around this issue.
BGP based signaling maybe?
You can make VPLS tunnel over each link and then add ECMP route to route over both tunnels.
Thanks,
I seem to ran into a different issue,
Only the first tunnel will establish.
I also tried manually specifying the transport address in LDP interface.
[admin@R1] /mpls ldp neighbor> print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello,
V - vpls
 #      TRANSPORT       LOCAL-TRANSPORT PEER                       SEN
 0 D TV 172.16.1.2                                                 yes
 1 D TV 172.16.0.2                                                 yes
 2 DO   1.1.1.2         172.16.0.1      1.1.1.2:0                  no
[admin@R1] /interface vpls> print
Flags: X - disabled, R - running, D - dynamic,
B - bgp-signaled, C - cisco-bgp-signaled
 0 R   name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:B2:24:43:43:72
       arp=enabled arp-timeout=auto disable-running-check=no
       remote-peer=172.16.0.2 vpls-id=1:2 cisco-style=no cisco-style-id=0
       advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=default
 1     name="vpls2" mtu=1500 l2mtu=1500 mac-address=02:B2:24:43:43:72
       remote-peer=172.16.1.2 vpls-id=2:2 cisco-style=no cisco-style-id=0
You have the same MAC address on both interfaces.
It is probably not a good idea to use Winbox’s Copy facility for this, which is what I assume you did to end up with it like that.
Thanks, did not even realize.
Did create new interfaces now but still the same behavior
Let’s see the config. then.
Are you sure the problem isn’t at the other end of the link?
Here we go
R1
[admin@R1] > export
add name=bridge1
add name=bridge2
set [ find default-name=ether1 ] disable-running-check=no mtu=1580
set [ find default-name=ether2 ] disable-running-check=no mtu=1580
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:24:C1:6D:20:B1 name=vpls1 \
add disabled=no l2mtu=1500 mac-address=02:B2:24:43:43:72 name=vpls2 \
/routing ospf instance
set [ find default=yes ] router-id=1.1.1.1
add address=172.16.0.1/30 interface=ether1 network=172.16.0.0
add address=172.16.1.1/30 interface=ether2 network=172.16.1.0
add address=1.1.1.1 interface=bridge1 network=1.1.1.1
add address=2.2.2.1 interface=bridge2 network=2.2.2.1
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/mpls ldp
set enabled=yes lsr-id=1.1.1.1 transport-address=1.1.1.1
/mpls ldp interface
add interface=ether1 transport-address=172.16.0.1
add interface=ether2 transport-address=172.16.1.1
/routing ospf network
add area=backbone network=1.1.1.1/32
add area=backbone network=172.16.0.0/30
add area=backbone network=172.16.1.0/30
add area=backbone network=2.2.2.1/32
/system identity
set name=R1
R2
add name=bridge1
add name=bridge2
set [ find default-name=ether3 ] disable-running-check=no mtu=1580
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:93:47:97:D4:C9 name=vpls1 \
    remote-peer=172.16.0.1 vpls-id=1:2
add disabled=no l2mtu=1500 mac-address=02:E9:50:DF:D5:BA name=vpls2 \
    remote-peer=172.16.1.1 vpls-id=2:2
set [ find default=yes ] router-id=1.1.1.2
add address=172.16.0.2/30 interface=ether1 network=172.16.0.0
add address=172.16.1.2/30 interface=ether2 network=172.16.1.0
add address=172.16.2.1/30 interface=ether3 network=172.16.2.0
add address=1.1.1.2 interface=bridge1 network=1.1.1.2
add address=2.2.2.2 interface=bridge2 network=2.2.2.2
/ip dhcp-client
/mpls ldp
set enabled=yes lsr-id=1.1.1.2 transport-address=1.1.1.2
/mpls ldp interface
add interface=ether1 transport-address=172.16.0.2
add interface=ether2 transport-address=172.16.1.2
add disabled=yes interface=ether3
add area=backbone network=172.16.2.0/30
add area=backbone network=1.1.1.2/32
add area=backbone network=2.2.2.2/32
/system identity
set name=R2
You cannot do this setup with LDP signaled VPLS (only one VPLS will be active), here is the example with BGP signaled VPLS:
https://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS_extended
Thanks that seems to work
Only issue now is it creates dynamic interface, if one BGP drops and reconnects the interface name changes, but i will try and figure it out
Two options,
  • script that checks if dynamic interface was changed;
  • use bridge per dynamic interface and in static configuration work with bridge interface.
