Hi, i’m struggling with issue related OVPN default route.
I have MT router connected to OVPN server running on Debian. MT(os7.3) interface IP is 192.168.201.6 and Debian 192.168.201.5. The connection is running properly and it’s tested, so i can access OVPN’s GW on 192.168.201.1 on server side. MT LAN has 10.0.0.0/24 and MT LAN IP is 10.0.0.1.
The goal is to get for specific source IP’s route through the VPN GW 192.168.201.1. I’ve attached some screenshots from actual config.
Also i’m sharing tutorial i’ve been using to get that work:
http://forum.mikrotik.com/t/internal-clients-cannot-ping-remote-gateway-ipsec-vpn/155558/1 for getting up the bridge for the LAN to see OVPN GW 192.168.201.1
Is there anyone familiar with this one?
