MT pppoe and radius
Im using MikroTik as a pppoe server (access concentrator).
I keep all my ppp secrets on MT.
I would like to extend to radius but i have no experience with it.
What kind of Radius server is easy to use, and will cooperate with MT.
I would like to be able to add users for a limited time (say one month) so that radius will disable them after end date of their payement.
This might be a stupid question but is there a radius server with webserver integrated so users can log in and change their password, or you have to work with databases and link it to another webserver.
thanks.
try http://www.evolynx.com if you want it on a windows machine
this works fine here
I am using Freeradius server and it is very easy to configure and operate it. And it can use MySQL for stored data about users so it is easy for you to manage it, because you have many windows tools for accessing MySQL. After installation you will not need to access radius, only mysql.
Can you share your PPPoE Server config ? as we are heading the same way !
Do u do NAt on MT ?
