What you think about topic??
What better for CPE and what better for BS? I don’t case about datasheet, i care about your experience with those cards.
If we share experience about we can avoid failure and bad buy!
Thanks!
Francesco
Thanks!
Francesco
My experience is that you should read and care about the datasheets.
Both UBNT and MK have pretty accurate data sheets and you should use them when making your selection.
We have R52, R52H, SR5, XR5 in use now and R5H next week.
All these cards work according to spec. It’s simply a matter of making the calculations and figuring out which card is best for each situation.
BTW, since the SR5 and XR5 cost the same and the XR5 is better, we don’t buy SR5s anymore.
