MT support refused to fix issues. And lies. Again.
MT hardware routers have old issue with low and unstable speed via VPN tunnel on high latency WAN link: http://forum.mikrotik.com/t/slow-speed-through-gre-ipsec-tunnel/128714/1
I also create ticket SUP-22475, but MT support refused to fix issue.
Do you want to know what reason they gave?
There is nothing to fix, it is the nature of TCP protocol.
:facepalm:
Yes, they are honestly lying.
Testing shows that the issue occurs only in hardware MT routers, and it does not exist in the virtual CHR.
But they refuse to admit that there is a issue, and answer “There is nothing to fix, it is the nature of TCP protocol”.
The solution is simple, use CHR or go away from MikroTik,
the world is full of other vendors and other vendors forum.
No?
@mikrabuser
How many more shitty topics are you going to open?
Go buy a TP-Link or something and shit all day in their forum too.
