I’m trying to setup 802.1x with EAP-TLS to secure wifi, but the RADIUS/connection server is a Azure VM, to which I can connect with a IPSEC tunnel.
The problem is that when trying to connect to the wifi, I get an error that I can’t connect. With some help I’ve discovered that with Wireshark I see (on the RADIUS server) that the framed MTU is 1400, which causes the failure of sending back the client-certificate through the IPSEC tunnel.
If I understand it correctly that’s because it exceeds the max packet size of 1500, or some device is forcing the packets to a size of 1400 which causes the packets to be fragmented (incorrectly)?
Now I’ve looked at all the devices, and as far as I can tell every device is set at the default MTU size of 1500, and I already had a firewall mangle rule (chain=forward action=change-mss new-mss=1350 passthrough=yes tcp-flags=syn prot) in place, but that doesn’t seem to matter. I’ve searched online and found some info about clamping MSS to PMTU, so I’ve added the rule: chain=forward action=change-mss new-mss=clamp-to-pmtu passthrough=yes tcp-flags (and disabled the other mtu rule).
Unfortunately, that doesn’t work either (even after resetting the VPN tunnel for a new connection). In my wireshark trace I still see the MTU size of 1400, so it looks as if the clamping to path-mtu is not working. Anyone got any ideas on how to proceed and get it working?
My setup is as follows:
internet > ISP-modem (configured to blindly forward everything to) > Mikrotik hEX PoE (routerOS 6.46.4) > Managed switches/Ubiquity Unifi AP’s > cients.
