Multi-dimensional arrays
I’m wondering if it’s possible to create a simple multidimensional fixed array and access it in a reasonable fashion…
Something like the following
:local WANStatus (1,1,0; 1,2,0; 1,3,0; 1,4,0; 2,1,0; 2,2,0; 2,3,0; 2,4,0)
:put $WANStatus[1,1]
:set {$WANStatus[1,1] → 3}
I’m not really grokking how RouterOS handles Arrays, and the documentation in this respect seems rather lacking. (Or my code-fu is too weak to properly parse what’s there, just as likely)
If someone could provide a syntactically valid example of the above that would be much appreciated.
:local WANStatus ({{1;1;0};{1;2;0};{1;4;0}});
If my parsing skills are any better (I haven’t tested it…)
Regardless, modifying parts of the array is not possible. You need to set the whole variable again.
Figured out something that works well enough for my purpose, I think.
It’s a bit uglier than I hoped for, but should work well enough.
:local WANStatus {101=2; 102=2; 103=2; 104=2; 201=2; 202=2; 203=2; 204=2}
:local ConnPrefix 100
#Display and change value 4 for connection 1
:put $WANStatus
:local Conn 1
:local value 4
:put ("Existing value = " . ($WANStatus->[:tostr (($ConnPrefix*$Conn)+$value)]))
:set ($WANStatus->[:tostr (($ConnPrefix*$Conn)+$value)]) 5
:put $WANStatus
Can be made cleaner by pre-computing the key string and just using a variable when accessing the array
:local arrayKey [:tostr (($ConnPrefix*$Conn)+$value)]
:set ($WANStatus->$arrayKey) 5
The big, and somewhat unintuitive for me, takeaway is that the key must be a string, even if you’re just using decimal numbers.
I don’t see an easy way to filter the results of a :foreach through the array, but since this is a fixed array with known size, I can loop through it myself easily enough.
Almost there, actually I can work around this, but it’s not perfect, so I’m going to throw it out there:
Compare this code
# Statically defined array, working properly
  :local testArray {11=1; 12=1; 21=1; 22=1}
  :local testRows 2
  :local testCols 2
  :local testRowSize 10
  :put $testArray
  :for x from=1 to=$testRows step=1 do={
    :for y from=1 to=$testCols step=1 do={
      :local value ($testArray->[:tostr (($testRowSize * $x) + $y)])
      :put ("Type of row $x column $y is $[:typeof $value] with value $value")
Which outputs this:
11=1;12=1;21=1;22=1
Type of row 1 column 1 is num with value 1
Type of row 1 column 2 is num with value 1
Type of row 2 column 1 is num with value 1
Type of row 2 column 2 is num with value 1
To this code which builds the array dynamically
# Dynamically defined array based on the above static array
  :local testRows 2
  :local testCols 2
  :local testArray
#      :put $testArray
      :local coord (($testRowSize * $x) + $y)
      :if (($x = 1) and ($y = 1)) do={ \
        :set testArray {11=1}
      } else={ \
        :set ($testArray->[:tostr $coord]) 1
  :put $testArray
And outputs this:
11=1;12=1;21=1;22=1
I’ve got to use an ugly kludge to start the array, since RouterOS won’t let me use variables in a :set statement for an array
 else={ \
Is this a shortcoming in the language, or am I an idiot?
It is possible to define matrix and edit or get each individual value.
:global a {{1;2;3};{4;5;6}}
:put ($a->0)
1;2;3
:put ($a->0->1)
2
:set ($a->0->1) 9
:environment print
a={{1; 9; 3}; {4; 5; 6}}
There’s still a bit of magic required to build a matrix programmatically.
I submit the following for whoever may find it useful:
  :local rows 4
  :local cols 4
  :local fillVal 0
  :local testArray
  :for x from=0 to=($rows - 1) do={
    :for y from=0 to=($cols - 1) do={
      :if ($y = 0) do={
        :set testArray ($testArray, {{$fillVal}})
      } else={
        :set ($testArray->$x->$y) $fillVal
    :put ($testArray->$x)
can find deal with a matrix?
:put [ :find $a 9 -1 ]
gives an empty result.
So what is the lesson learned here? An array is not a string.
Then make it a string: :put [ :find [:tostr $a] 9 -1 ]
https://wiki.mikrotik.com/wiki/Manual:Scripting says it can search arrays as well
thx for that :slight_smile:, that would help in “simple” cases.
:global UserDatabase [:toarray ""];
# The key for the array is the username of the user.
# The structure of every user record is as follows:
# password | email | tel | last IP | something | something else |
:set ($UserDatabase->"username1") {"supersecret";"username1@example.com";"+123456789";"0.0.0.0";0;0};
:set ($UserDatabase->"username2") {"megasecret";"username2@example.com";"+987654321";"0.0.0.0";0;0};
# Printing specific property (column) of the data for specific user:
:put ($UserDatabase->"username1"->0);
know I want to:
  1. find the index of the array username2
  2. extract this the username2-array from UserDatabase-array by index
currently, I could your approach to check if the username2-array exists. If so, called it by its name (named array).
Remember that everytime you add item or create an array, the main keys are sorted…
:set ($UserDatabase->"username4") {"megasecret";"username4@example.com";"+987654321";"0.0.0.0";0;0};
:set ($UserDatabase->"username5") {"megasecret";"username5@example.com";"+987654321";"0.0.0.0";0;0};
:set ($UserDatabase->"username9") {"megasecret";"username9@example.com";"+987654321";"0.0.0.0";0;0};
:set ($UserDatabase->"username3") {"megasecret";"username3@example.com";"+987654321";"0.0.0.0";0;0};
:put $UserDatabase
username1=supersecret;username1@example.com;+123456789;0.0.0.0;0;0;
username2=megasecret;username2@example.com;+987654321;0.0.0.0;0;0;
username3=megasecret;username3@example.com;+987654321;0.0.0.0;0;0;
username4=megasecret;username4@example.com;+987654321;0.0.0.0;0;0;
username5=megasecret;username5@example.com;+987654321;0.0.0.0;0;0;
username9=megasecret;username9@example.com;+987654321;0.0.0.0;0;0
I use this “feature” to sort lists…
And about index… the name itself is the index, a numeric value do not exist…
:foreach index,content in=$UserDatabase do={:put $index; :put $content}
username1
username2
username3
username4
username5
username9
For search inside the array (on username’s part)
:global searcthis “username1”
:put [:typeof ($UserDatabase->$searcthis)]
array
:global searcthis “username30”
nothing
if nothing the index do not exist
If array (or any other variable types stored inside the array filed) the index exist (empty or not)
thx a lot :slight_smile:
