Multi-Link Client PPPoE
I looked around, did’ent find an exact answer, but..
How would you go about, MT with 3 NICS, each NIC in a VDSL modem, and then running three PPPoE Clients to the ISP. The ISP supports PPPoE MultiLink.
So, how do I tell MT to BOND all three of these?
Dennis
anyone? bump
You don’t, at least not using ML-PPP.
The easy way is to masquerade all outgoing traffic, and setup an ECMP default route. This does, however, rob you of the ability to use routable IPs internally.
The nice way, if your ISP will play this game, is to arrange for a dynamic routing protocol feed, and let ECMP self-generate on both routers. Doing this will allow routables to work, and will also automatically create nice redundancy (droping a link won’t drop connections, if done right).
Both work well, and we have quite a few customers doing these. If a customer is willing to throw a little extra cash at us, we will happily give them a feed. The easier, but less powerful NAT method does not require ISP cooperation.
–Eric
I thank you again for the answer. I understand what you are saying. The provider says that have done Muli-link PPPoE with other customers, so I guess I need another router in front of my MT box?
That would do it, so long as it supports ML-PPP.
–Eric
