Multi RIOM testing behind indiv. routers, same private IPs, data loss
Thanks a lot for your answer!
Trying to get things working, but no luck. Can you post your most up-to-date-and-working config?
In the second question, I tried to find is there´s a chance to route more than one ethernet port (maybe adding virtual interfaces), since PoE is not needed here.
Thanks again, best regards!
Here it is.
change the IP addresses, PoE settings, etc for your set up.
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether5 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full poe-out=\
    forced-on
set discover-interface-list=all
/ip settings
set send-redirects=no
add address=10.10.10.104/24 interface=ether1 network=10.10.10.0
add address=192.168.88.1/24 interface=ether2 network=192.168.88.0
add address=192.168.0.200/24 interface=ether5 network=192.168.0.0
add action=dst-nat chain=dstnat in-interface=ether1 to-addresses=192.168.0.63
add action=src-nat chain=srcnat out-interface=ether1 to-addresses=\
    10.10.10.104
/ip ipsec settings
set accounting=no
/snmp
set enabled=yes
/system identity
set name=router10
/system watchdog
set ping-start-after-boot=5h watchdog-timer=no
/tool bandwidth-server
set authenticate=no enabled=no
/tool netwatch
add host=192.168.0.63 interval=30s
/user aaa
set default-group=full use-radius=yes
@mcasanas: About multiple ports on same router:
http://forum.mikrotik.com/t/port-to-interfacing/97096/1
http://forum.mikrotik.com/t/how-to-allow-two-devices-with-same-ip-access-internet/115990/1
Still trying, thanks for your answers! Testing with 2 PC´s with same IP, rdesktop sometimes goes to one, some other times goes to the other…
