Hi all,
Just thought I’d post my scripts to turn the mode-button on WiFi units into a multi usage button.
There’s two scripts, one called mode-button which is what pressing the mode-button runs, the other is mode-action which has the actions in it and is run by the system scheduler.
# mode-button
# run by pressing the mode button
:global modeCount
:local maxCount 3
:local runDelay 10
:local runDelayFull "00:00:$runDelay"
:set $modeCount ($modeCount + 1)
:if ($modeCount > $maxCount) do={:set $modeCount 0}
:local modeTime ([/system clock get time]+($runDelayFull))
:local modeSchedule [/system scheduler find name=modeAction]
:if ($modeSchedule = "") do={
/system scheduler add name=modeAction on-event=mode-action start-time=$modeTime
# mode-action
# run by system scheduler
:global modeCount
:if ($modeCount = 1) do={
/system scheduler remove [/system scheduler find name=modeAction]
:set modeCount 0
:if ([/system leds settings get all-leds-off] = "immediate") do={
/system leds settings set all-leds-off=never
} else={
/system leds settings set all-leds-off=immediate
:if ($modeCount = 2) do={
:set modeCount 0
/system reboot
:if ($modeCount = 3) do={
:set modeCount 0
/system shutdown
As you can see from the code, a single press within 10 seconds will toggle the LEDs, a double press will reboot, and a triple press will shutdown. It can be modified for shorter or longer time for the button presses, and obviously more actions can be added or even removed if wanted.
