I have a local multicast udp stream enabled on my local lan (i.e. udp://239.1.1.1:5000). On Mikrotik router (latest router os) with default config and igmp snooping enabled that group is always active on lan bridge, even if there are no joins on that group in our local lan. The entry is also not present in MDB list on lan bridge.
The only way to disable this multicast traffic is to disable “unknown multicast flood” on that particular lan bridge port, but then that group won’t be visible on neighbour devices. This is a bug. The group should be visible in local MDB list and the traffic should only become active on mikrotik router when there’s at least someone who joined that group.
The issue is easily replicated with default mikrotik config on all routeros devices. It is also described here and I believe it was not resolved.
http://forum.mikrotik.com/t/igmp-snooping-not-working-on-crs326/139893/1
Can comeone please advise if there’s a solution to this matter or should I fill a bug report? This can become a bigger issue if you have a lot of multicast streams active on local lan devices.
