I am looking for an affordable Wireless Access Point which supports multicast to unicast translation and was hoping ROS has this implemented. I found the following thread on this forum which briefly discusses this, but it is from march 2012 (not implemented yet…): http://forum.mikrotik.com/t/iptv-solution-with-udpxy/57042/14
I am hoping that by now the feature is implemented…is this the case? We really need this option for an audio multicast application where current losses are huge due to the non-acked nature of the multicast implementation in WiFi.
→ natted traffic back to PC → VLC shows the original multicast and the translated unicast stream simultanuosly.
PC was on 172.16.5.250, XP with DOS-FFMPEG. Router was on 172.16.5.254, RB951Ui-2HnD with ROS 6.27
You can see the incoming and outgoing traffic on the same interface…
Best regards: CsXen
Unfortunately, this solution no longer works in ROS 7. There are two other ways to achieve this, but neither is quite as simple.
The first option requires a router with an ARM processor capable of running containers; you can write a small program for this that transforms any incoming data into whatever you need for the output.
The second solution is a bit more complex, but it can be doing simply by configuring the firewall with the appropriate parameters to handle multicast in an unusual way. I spent three days struggling with it before I finally got it working.
