I currently running a plain IPSec site-to-site connection between two RB750Gr3 (hEX) with the following setup:
On both sites I have provider routers in place (DHCP server & internet gateway) and behind that running the hEX (in bridge mode) acting as VPN gateways with plain IPSec (based on policies only). Both provider routers have static routes to the remote net with the hEX as the gateway. This setup is running fine and very fast.
On top of that I would like to route multicast traffic (mainly for SSDP) in both direction. On both ends I have services that should be discoverable from both sites.
I already read the following forum posts & docs:
- Working DLNA routing example (basic)
- DLNA over GRE ?
- Multicast over VPN for site-to-site
- Manual:Multicast detailed example
So my plan is to put a GRE tunnel on top of my IPSec in order to run PIM for multicast. However I would prefer to still route unicast via the plain IPSec due to performance reasons (plain IPSec seemed to be the best option based on my earlier tests).
Is this possible or am I forced to route also unicast over the GRE tunnel? None of the previous posts mention such a multicast/unicast split routing…
