Hi all,
i have succesfully configured an igmp proxy on a routerboard RB493G with mikrotik os 6.37 as follow:
two multicast servers on local subnet (192.168.0.2 and 192.168.0.3) sending out multicast streams respectively at groups 239.0.0.20 and 239.0.0.15
one client on Wan side that requests multicast streams with “join” igmp packets.
This configuration works well, i can see packets flowing from servers to client after a “join” and stop after a “leave” packet.
Now i need to implement a multicast server also on the wan side, so that the same users on local subnet can join and receive packets.. as the following image:
Afaik i can’t specifiy more than one upstream interface on a igmp-proxy ..
is there any way to achieve my need ?
Any kind of workaround or something ?
Thank you
Regards
I’ve been doing PIM-Sparse on Mikrotik for quite some time now. After a little learning curve, I have it working quite reliably. It should be easy enough to deploy for you.
Now, if Mikrotik would only integrate IGMP-Snooping…
Thanks all for your replies,
the pim-sm is the option i was afraid of… btw, i’m reading the wiki and i’ll test it today with my configuration.
…mmm.. I guess i have to set ETH1 (wan) as RP (rendez-vous point) ..
Brb..
Thanks ,
Bye..
Ok, using PIM it seems to work correctly..
i’ll post my configuration maybe it could be usefull for other users ..
With RB493G i have 2 switch chips, and by default it comes with all ports bridged..
I erased the default settings and i simply used two master port for each switch chip to communicate with cpu.
ETH2 - master port for ETH3, ETH4, ETH5
ETH6 - master port for ETH7, ETH8, ETH9
In Routing/pim i just added the interfaces, ETH1 and ETH2
I can transmit multicast from ETH2 (and its every slave interface) and join the stream from ETH1 (WAN).
I can also run a multicast server on WAN side (ETH1) and join streams from machines attached on ETH2 interfaces (and its every slave interface).
I noticed that it works without RP, is it because is taking a default 0.0.0.0 address as RP ??
Is my way right ?
Thank You.
