First of all sorry for my basic question but I´m really a noob when it comes to networking, not limited but also especially with Mikrotiks.
Situation is as follows:
I have a HAP ax3 acting as my main router. It provides 3 Wifi networks which are isolated from each other (private, guest and IOT).
It took me hours and reading through a lot of tutorials to get this going and there is for sure room for improvement but it works.
I bought a HAP ax lite as a wired AP bridge. Using a simple bridge setup I´m able to extend my main Wifi (private) just fine.
I fail to extend my other 2 Wifi networks as I´m not sure how to get this done. I guess I need additional bridges, similiar to the main router setup and configuration of additional DHCP clients getting IPs from the main router…unfortunately I can´t get this to work at all.
Here the configuration from my HAP ax lite (ap bridge). As said the main Wifi (private) is working ok, problems exists with other Wifi networks (e.g. tried guest so far).
I guess it´s related to VLAN tagging, do I need that if I have different bridges?
Hi all,
Sorry for reactivating such a old thread and thanks holvoetn and anav. The posted guide is in fact a very good starting point.
I have setup my main router accordingly to the Router/Switch setup and all is now properly separated using VLANs on a single bridge. This is working like a charm.
When it comes to connecting the AP (hap ax lite) I´m still a bit confused I have to say.
I followed the AP instructions in the same referred thread with the small difference that I also added in the physical ports besides the Wifi networks.
Currently I fail to really have the networks forwarded on the AP (no internet access).
Secondly I would like to reach the AP under 192.168.66.3 which I made static for the AP on the main router. This doesn´t work and when I apply the config I´m unable to connect to the AP again causing me to need to perform a reset.
I think it´s not much going wrong here but having a hard time finding the solution.
For you guys this is for sure quite obvious. Any help would therefore be greatly appreciated.
My dummy config based on the provided example looks like this.
# name the device being configured
/system identity set name="wired_AP"
# VLAN Overview
# 10 = BLUE
# 20 = GREEN
# 30 = RED
# 99 = BASE (MGMT) VLAN
# WIFI Setup
# Example wireless settings only. Do
# NOT use in production!
# Blue SSID
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key="password"
/interface wireless set [ find default-name=1-wifi-2GHz ] ssid=wired frequency=auto mode=ap-bridge disabled=no
# Green SSID
/interface wireless security-profiles add name=GREEN_PROFILE authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key="password"
/interface wireless add name=2-wifi-2GHz_guest ssid=wired_guest master-interface=wlan1 security-profile=GREEN_PROFILE disabled=no
# Red SSID
/interface wireless security-profiles add name=RED_PROFILE authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key="password"
/interface wireless add name=3-wifi-2GHz_IOT ssid=wiot master-interface=wlan1 security-profile=RED_PROFILE disabled=no
# Bridge
# create one bridge, set VLAN mode off while we configure
/interface bridge add name=bridge_LAN protocol-mode=none vlan-filtering=no
# -- Access Ports --
# ingress behavior
# Blue, Green, Red VLAN
add bridge=bridge_LAN interface=1-wifi-2GHz pvid=10
add bridge=bridge_LAN interface=2-wifi-2GHz_guest pvid=20
add bridge=bridge_LAN interface=3-wifi-2GHz_IOT pvid=30
add bridge=bridge_LAN interface=ether2 pvid=10
add bridge=bridge_LAN interface=ether3 pvid=10
add bridge=bridge_LAN interface=ether4 pvid=10
# egress behavior, handled automatically
# -- Trunk Ports --
# ingress behavior
# Purple Trunk. Leave pvid set to default of 1
add bridge=bridge_LAN interface=ether1
# egress behavior
/interface bridge vlan
# Purple Trunk. L2 switching only, Bridge not needed as tagged member (except BASE_VLAN)
add bridge=bridge_LAN tagged=ether1 vlan-ids=10
add bridge=bridge_LAN tagged=ether1 vlan-ids=20
add bridge=bridge_LAN tagged=ether1 vlan-ids=30
add bridge=bridge_LAN tagged=bridge_LAN,ether1 vlan-ids=99
# IP Addressing & Routing
# LAN facing AP's Private IP address on a BASE_VLAN
/interface vlan add interface=bridge_LAN name=BASE_VLAN vlan-id=99
/ip address add address=192.168.0.3/24 interface=BASE_VLAN
/ip address add address=192.168.66.3/24 interface=bridge_LAN network=192.168.66.0
# The Router's IP this AP will use
/ip route add distance=1 gateway=192.168.66.1
# IP Services
# As in the example nothing configured but is this really the way to go?
# VLAN Security
# Only allow ingress packets without tags on Access Ports
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=1-wifi-2GHz]
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=2-wifi-2GHz_guest]
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=3-wifi-2GHz_IOT]
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether2]
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether3]
set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether4]
# Only allow ingress packets WITH tags on Trunk Ports
/interface bridge port set bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether1]
# MAC Server settings
# Ensure only visibility and availability from BASE_VLAN, the MGMT network
/interface list add name=BASE
/interface list member add interface=BASE_VLAN list=BASE
/ip neighbor discovery-settings set discover-interface-list=BASE
/tool mac-server mac-winbox set allowed-interface-list=BASE
/tool mac-server set allowed-interface-list=BASE
# Turn on VLAN mode
/interface bridge set bridge_LAN vlan-filtering=yes
You have a godawful way of showing a config LOL… I tell that to pcunite all the time
Bridge does not get an address… the IP address of the device is the address given via the management base vlan.
I recommend making one port access to config the device OFF the bridge… works well.
add ingress-filtering=no name=bridge_LAN vlan-filtering=yes
set [ find default-name=ether1 ] name=trunk
set [ find default-name=ether4 ] name=emergaccess
/interface vlan
add name=BASE
/interface wireless
{ as required }
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=trunk
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=1-wifi-2GHz pvid=10
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=2-wifi-2GHz_guest pvid=20
add bridge=bridge_LAN ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=3-wifi-2GHz_IOT pvid=30
add bridge=bridge_LAN tagged=ether1 untagged=ether2,ether3,1-wifi-2GHz vlan-ids=10
add bridge=bridge_LAN tagged=ether1 untagged=2-wifi-2GHz_guest vlan-ids=20
add bridge=bridge_LAN tagged=ether1 untagged=3-wifi-2GHz_IOT vlan-ids=30
add bridge=bridge_LAN tagged=ether1,bridge_LAN vlan-ids=99
add interface=emergaccess list=BASE
add address=192.168.0.3/24 interface=BASE_VLAN network=192.168.0.0
add address=192.168.36.1/24 interface=emergaccess network=192.168.36.0 comment="ether4 access off bridge"
set allow-remote-requests=yes servers=192.168.0.1 { Note: Done so all dns requests use trusted subnet }
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.0.1 comment="ensures route avail through trusted subnet gateway"
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=x.x.x.x
set api disabled=yes
set api-ssl disabled=yes
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.0.1
/tool mac-server
Hi anav,
You are so damn fast in answering! Very much appreciated!
This helped a lot, I got the AP to work and all 3 Wifi networks are working fine now.
One thing which I´m having a hard time to understand is the emergency access and generally the AP access via Winbox.
Please correct me if I´m wrong but with this setup the idea is that you only can connect via Winbox on the emergency access port (ether4) via MAC, correct?
I cannot manage to connect to the AP from … lets say the private VLAN (pvid 10). Also the AP itself doesn´t seem to have any internet access. I cannot ping the outside world nor can I check for RouterOS updates. Not quite sure if that is intended. Not quite sure I got the vlan tagging correct or maybe the ip adressing part is missing something.
Sounds like you may have some errors. but not sure.
Post your latest config for review…
In terms of access to the AP, you should be able to from any PC on the main router, on the 99 network, access the AP via winbox.
If you had a port on the AP (access port) for vlan99 that would also work, however, its better to use an off bridge port.
Most of the pain in the butt happens when you screw something during bridge vlan configuration and its easy to get locked out and start from scratch. Then you would not be able to access from the main router management subnet, nor a local port assigned to vlan99.
Much safer to config from or have an emerg access via an off bridge port.
So you only set the address, take the port off the bridge and then plug in your laptop to that port.
Change your IPV4 settings appropriately and bobs your uncle.
Ahh while looking just found that there is indeed still a bigger problem. I forgot to turn vlan filtering on the bridge on (typically I do that at the end to be not cut off during configuration). Now after I did that the internet access on the WIfi networks is gone again
So yes quite sure something is not as it should be. Potentially also a problem on my main router as that config is a bit clunky as it has been grown over time.
MainRouter: mainrouter.rsc (12 KB)
AP Config (really based on your correction) - without the unneccesary commenting AP.rsc (2.83 KB)
Thanks for your time!
Oops you have main router errors showing, the question here is why do you have bridge filters at all? Remove for now please. /interface bridge filter # no interface
add action=drop chain=forward in-interface=*9 # no interface
add action=drop chain=forward out-interface=*9 # no interface
add action=drop chain=forward in-interface=*A # no interface
add action=drop chain=forward out-interface=*A
Should be set to BASE
set discover-interface-list=VLAN
There appears to be no trunk port to the AP??? as evidenced by the /interface bridge port settings ???
The /interface bridge vlan settings provide no clues as to what is going on.
Set detect internet interface=NONE
Simplify (when using all vlans, bridge is not a list member )
add name=WAN
add name=LAN
add name=BASE
add interface=wireguardVPN list=BASE { to allow admin remote access to config router if necessary )
If you manually added netmask to this address line, remove it!
add address=192.168.66.0/24 comment=defconf dns-server=192.168.0.1 gateway=
192.168.66.1 netmask=24
Remove this static DNS setting!!! /ip dns static
add address=192.168.66.1 comment=defconf disabled=yes name=router.lan
Firewall rules adjusted /ip firewall address-list ( using static dhcp leases for local addresses } add address=192.168.0.A/32 list=Authorized comment=“admin local desktop wired”
add address=192.168.0.B/32 list=Authorized comment=“admin local laptop wired”
add address=192.168.70.X/32 list=Authorized comment=“admin remote wg laptop”
add address=192.168.70.Y/32 list=Authorized comment=“admin remote wg smartphone/ipad”
add address=192.168.36.2/32 list=Authorized comment=“admin on AP”
Note1: If you want to be able to access router and AP from private subnet,
add private subnet vlan10? to the BASE interface list
add ip addresses for admin to the source address list Authorized
Note2: It is not clear what the role of the other wireguard VPN is…so left it out of firewall rules
Once detailed, it will be easy to make adjustments.
Add route for admin on AP…
add dst-address=192.168.36.2 gateway=192.168.0.3 routing-table=main
MISSING wireguard allowed IP setttings??? or am I blind?
Thanks for the detailed response. I just recognized yesterday, actually before your reply that I haven´t configured a trunk (dumb).
A lot of the other garbage still in is from refactoring the main router from the initial multiple bridge based setup to VLAN. Maybe I should have started from scratch instead.
Let me try to go through one by one:
Thanks to you the AP is so far ok.
Bridge filters are removed. Indeed a leftover.
Done
Trunk port (ether2) was indeed missing as was added now. I hope I did that in the correct manner.
Ok does this look better now in the new export?
Ok deactivated. This actually comes from using the Mikrotik Android app to access the device config. Seems I activated it there by accident.
Simplification completed. Makes sense to remove the bridge
Hey good catch, removed netmask from address.
Mhh I´m honestly not sure where this is coming from. I use Cisco OpenDNS to block down access to certain internet categories. In order to not allow users to simply change their DNS manually I tried something, maybe this is it. I cannot remember. I anyway do that via NAT.
Firewall rules cleaned. Are all the other rules I have not of value anymore (I refer to the currently disabled ones)?
Note1: Ok I added private_VLAN (10) to the BASE interface list. I also added one IP address to the Authorized list. In order to make sure this address stays the same I just went to DHCP Server and made the lease address static.
Note2: The first wireguard is for a roadwarrior setup. The other wireguard is a site2site setup which should be up and running permanently. This was working fine in the past. I think to get this enabled I just add the wireguard to the LAN interface list, correct?
Ok will add that on the AP.
Indeed I removed that from the config with some other scripts and schedules on the router but its there in the new export.
Set to NONE mac-server by itself is not a secure protocol /tool mac-server
Modify router to remote router subnet TO:
add dst-address=192.168.178.0/24 gateway=wireguard_perDfels routing-table=main
Now lets look at bridge ports and bridge vlans
Ports looks okay, modify /interface bridge vlans to: { i prefer manual entry of untagged both are valid, but this way I can cross check with bridge ports to see if both line up )
Since you are proving NTP from the router adjust this rule!! add action=accept chain=input comment=“user access to services” dst-port=53,123
in-interface-list=LAN protocol=udp
Got to this forum as I have a co-worker who is a fan of mikrotik and keeps recommening it.
I’m also considering a router and an aditional AP for the second floor, but want to configure a vlan for IOT devices and I want the adiciotnal AP to replicagte the riginal SSID/Vlans
Btw if someone cares to recommend hw for this, that would be great. If possible something with wifi6 to make a bit more future proof.
All you require is included in this thread, unless using capsman and thus its slightly different.
So have at it. When you have a working config or close to working config and need help just ask.
@jmpaiva: I guess you can just have a look at my latest config to get a good understanding on how it would like in your setup. There are a few small issues still but it´s a good start.
For devices it really depends on what you need, there are quite a lot of devices from Mikrotik. I decided on a HAP ax3 as my main router and a HAP ax lite as Access Point. Especially for the ax lite there are certainly better devices when it comes to WiFi coverage but it´s sufficient for me. Can´t expect much more for such a cheap device.
@anav: I implemented the latest proposed changes and understand that it´s better to add the untagged interfaces manually for clearness. NTP started working now as well.
One major problem is still around. I don´t have internet access on the AP wifi networks. The AP itself has internet access when accessed via the off bridge port.
If connecting to the wifi networks it seems like I don´t get a proper IP from the DHCP server pools but I can´t identify any problems there. Maybe I also srewed some of the tagging up. Really unsure. There are no changes to the config I uploaded yesterday, except the latest ones you posted. Pretty sure it´s a small and stupid problem.
Hi anav,
Really stuck currently, likely very easy.
Here are the mainrouter and ap configs. mainrouter.rsc (19.4 KB) ap.rsc (2.99 KB)
Thanks a lot! I owe you multiple drinks.
You added an extra route here, but it should not cause any failures…should be removed.
add comment=“ensures route avail through trusted subnet gateway” disabled=no
dst-address=0.0.0.0/0 gateway=192.168.0.1 add disabled=no dst-address=192.168.36.2/32 gateway=192.168.0.3
routing-table=main suppress-hw-offload=no
Other than that I cannot spot anything on the AP.
ROUTER
Could not spot anything on the main router either!
Hi anav,
Ok removed the route and rebooted both units. Nothing changed. Still no correct DHCP assignment on any Wifi network from the AP.
I´ll try to have another close look tomorrow.
