Hi Guys,
I’ve just recently upgraded from a RB750GL to a RB2011UiAS-2HnD-IN, specifically so i can get rid of the separate wireless AP i was previously using.
I have eth1 bridged into an ADSL modem for PPPoE. eth2 runs off to a much larger switch. This separate switch used to be where my wireless AP was connected. On my 750GL i just had to mirror eth2 to eth3 and connect my IDS and all was well.
Now with the R2011, i have eth1 again bridged to the modem, and eth2 off to the larger switch, but i also have the internal wireless enabled and working on the RB2011.
I’m struggling though to figure out how i can setup the RB2011 though so that all traffic through eth2 - but also wlan1 is mirrored out of eth3.
Any suggestions would be much appreciated. The wireless interface doesn’t show up in either switch1 or switch2 - so i can;t create a interface mirror rule with it.
And the bridge interface on the RB2011 doesn’t seem to be the right place to setup a mirror either.
Thanks,
Scott
