Hi there!
As Android dropped support for L2TP/IPsec in new versions, it looks like L2TP/IPsec should be dead, but we are using it on Windows clients because of good support by OS.
As per Sindy in his epic article:
http://forum.mikrotik.com/t/multiple-road-warrior-l2tp-ipsec-clients-behind-nat-solved/118206/1
Is there any change in behavior in ROS7? It looks pretty same for me, but maybe I’m missing something in that.
Basically I have working L2TP/IPsec server on Mikrotik, integrated with Active Directory, clients are connecting to the server without problems. Problem comes when there are multiple colleagues in the same hotel for example. They are all have the same source IP address and the last connected kick-off the one connected before.
Is there any new solution for this on ROS 7?
Best Regards,
Vanikcz
