Multiple routers and one CLI command
Is it possible to execute the same command on multiple routers, using The Dude, some SSH scripts or other tools?
If it’s not possible on Dude, it’s a nice suggestion, huh?
Run a script or API which connects to each router and executes the command.
Thanks for answer. Yeah, thought about that, but I probably won’t be able to create it. Do you have one?
Not a very elegant solution, but for ocasional use try ‘clusterssh’. For a more robust management API or scripting will be your best bet.
You can also set up SSH keys and issue commands via SSH:
ssh -i private.key yourusername@192.168.88.1 '/system resource print'
Hmm, seems like a solution. I’ll try “clusterssh” and the keys setup you’ve written. Thank you, guys!
…btw, it will be really great to have that feature in Dude too, since it already can show up a Terminal window. :sunglasses:
EDIT: PuttyCS seems useful too.
