I have a Cap Ac which is currently used for testing Vlans. There are 3 SSID's defined on the 2.4 GHz band. But I cannot activate all 3 SSID's simultaneous. So it is either wifi_10 with wifi_90 or wifi_10 with wifi_20. They don't run all three.
The third SSID gets an error ' failed to create interface'.
Use one of the VLANs instead for management, don't attach an IP address to the bridge if you are using VLANs
Also I think you don't need datapath with wifi qcom ac drivers as they don't support dynamicly assigning VLANs and you already set VLANs manually to wifi interfaces.
Is this the complete config??
Need complete config to make assessments.
For example, which vlan is 192.168.0.25 associated with,
and I fail to see the vlan assignement for management associated with 192.168.0.25???
what is on ether1 (likely your connection to an unidentified device and ether2????
I see no connection to an upstream router or switch for example for any management vlan?
I find a good guideline to ROS setup is to specify as little as needed . . . I run multiple SSIDs in a similar environment, and have never set a MAC . . . the system figures it out for you, avoiding this kind of stuff . . . WinBox, WebFig, or CLI, this still applies. If you don't know why you are setting a parameter, seriously consider that perhaps you should not be . . . (This suggestion is based on the plethora of problems seen here caused by folks thinking that they had to put something in for every parameter on a screen or command . . . )
To create the SSID wifi_90 I used the copy functionality. This resulted in a duplicate MAC address. To solve it I created a fourth wifi record but now using 'New' and nor 'Copy'. Winbox then creates a new record with a different MAC address. If you then look at the MAC addresses you can see the logic that Winbox uses to create new MAC addresses. Then I changed the MAC address of wifi_90.
I could also delete the wifi_90 and create it again using 'New'.
I'be been using the "configuration" tab for secondary SSIDs (that way I can apply it to multiple AP's) and only have Namee, Mode and SSID filled in, and drop it in the "configuration" section of the WiFi entry along with setting the master, and the MAC fills with all zeros, and have never had an issue. Clearly not the only way, but it has worked for me, fwiw.
(It looks like you are using wifi-qcom, if not, that may not be valid.)
