Hi there,
I have an RB3011UiAS and a big problem…
I have multiple external IP addresses on multiple WAN ports, one address for each port. Reason: my ISP can only assign one IP address per MAC…
Second, I have multiple servers behind it, two of them are web servers. And no, they can’t be on the same machine, because one is Linux, the other on Windows.
What I want to do is the following:
WAN Port 1 → Web Server 1
WAN Port 2 → Web Server 2
the first web server is working, the second one not.
The router is currently resetted without default config.
Here’s what I have now:
MikroTik RouterOS 6.46.4 (c) 1999-2020 http://www.mikrotik.com/
# model = RouterBOARD 3011UiAS
add address=192.168.0.4/24 interface=ether10 network=192.168.0.0
/ip dhcp-client
add disabled=no interface=ether1
add disabled=no interface=ether2
add disabled=no interface=ether3
add action=dst-nat chain=dstnat comment="WebServer1 HHTP" dst-port=80 in-interface=ether1 log=yes protocol=tcp to-addresses=192.168.0.32
add action=dst-nat chain=dstnat comment="WebServer1 HHTPS" dst-port=443 in-interface=ether1 log=yes protocol=tcp to-addresses=192.168.0.32
add action=dst-nat chain=dstnat comment="WebServer2 HHTP" dst-port=80 in-interface=ether3 log=yes protocol=tcp to-addresses=192.168.0.15
add action=dst-nat chain=dstnat comment="WebServer2 HHTPS" dst-port=443 in-interface=ether3 protocol=tcp to-addresses=192.168.0.15
another challenge: I don’t have fixed IP addresses from the ISP, so everything is DHCP.
I understand that srcnat should solve my problem, but:
.) I haven’t got it to work
.) the external IP address must be dynamic, so everything has to be solved with interfaces…
Please help a noob ![]()
needless to say: I’m a bloody beginner ![]()
