Great appreciation is given in advance for all help. I’ve been stumped by what I thought would be simple for two days now.
RB333 RouterOS 3.7 Atheros R52H 2.4GHz B/G band 2432 (Channel 6).
My goal is to use Access Lists to authenticate my customers via MAC, and allow each customer to use their own wep key.
I have everything working fine except for the multiple wep keys.
I need some step by step assistance on how to correctly set the wireless interface, security profile, and access list rules. I have tried so many different configurations, I’m burned out.
Is it even possible to authenticate by MAC and then, using the matching access list rule assign the correct wep key? I’m assuming that is what ‘private-algo’ and ‘private-key’ are for.
I have about 65 customers, each needing their own wep key.
I tried following the example in the online docs, the one that builds Station1 and StationX security profiles, but it does not work. The only difference between the example and my test is that the example ran at 5GHz and I’m at 2.4GHz.
In that example, I don’t even see where the Station1 security profile ever gets used
