Multiwan?
i have RB951Ui-2HnD.
Its possible to use multiwan in this model?
i have 2 internet conection 11 mb and another one 84mb
can i bound those 2 conection and get 95mb?
if this model cant do it, tell me witch can.. cheapest first.
thanks!
You can use more wan lines and distribute the connections between them according to some rule. Look for pcc. If you want to bond the lines, you need the support for this on the second side also…
i’m very new to this and cant find a guide. What i want to do is something like this https://www.youtube.com/watch?v=5RiqRBQLIfM to increase my upload speed. both internet are same isp.
If it is the same isp ask him how he is able to bond those lines and what you need to set on your side. Otherwise you can only distribute the newly opening outgoing connections amongst the lines from your side.
Its better to use different IP block like 1.1.1.0/29 and 1.1.2.0/29, and you should follow ecmp or pcc mathod.
