Must manually reconnect after power loss
Hi all,
Pretty new to Mikrotik. I have a hEX S running, connected to internet via pppoe on ether1 port.
I have noticed that after every power loss of the router, I dont have internet access until I manually reconnect the pppoe connection throughout Winbox.
Is that expected?
How can I overcome this?
Thanks!
Do you use DHCP-client and PPPoE-out on the same port?
Not sure. How do I check it?
In winbox I see that there is a DHCP client on ether1 interface, however it’s status is “stopped”.
Should I remove it?
In addition I can tell that I do see the pppoe status as “conncted”, but only after I push Reconnect, I gain internet access again.
Stopped or disabled? Did you check this after PPPOE reconnected?
In the status I see it as ‘Stopped’
Also after reconnecting it is still ‘Stopped’
If your wan connection is handled by the pppoe settings, then you should disable or remove ip dhcp client.
