Hello everyone, I have to say that I have been very happy with my mikrotik ikev2 vpn server with android clients for many months, configured with this tutorial https://www.youtube.com/watch?v=JYLbNWOCc2c&t=208s. But about 4 days ago it stopped working out of nowhere, the vpn connects to the mikrotik, but the client connected to this vpn now does not browse or reach the lan ip, I have tried with several mikrotik that have this configuration with different internet providers and the same thing happens, the android client has not been updated, I attach the configuration script if someone can give me a start on where to start to fix it please, I loved this configuration because of how simple it was.
I am having this exact same issue using IKEv2/IPSec PSK. This setup worked a few months back and when I went to use it recently the Android device (Samsung S24+) cannot ping the router or an device behind it. However, from the router and any device behind it on the LAN, I can ping the android device and get a reply. I’ve looked and cannot seem to figure out why this is happening. Hopefully someone here can point us in the right direction.
I have exactly the same problem. A connection can be established from the VPN client (Android 13, also Android 14 - IKEv2/IPSec RSA), but nothing can be reached either in the local network or on the Internet. Clients in the network can reach the VPN client.
No settings have been changed and no updates have been made recently.
It stopped working from one day to the next.
Edit:
I no longer use the native VPN in Android, but Strongswan instead. It works then again. However, it’s still very strange.
Personally, I use sha1, sha256, aes-256 and pfs-group=none for proposals and sha256, aes-256, modp1024 and modp2048 for profiles and it works for my native Android VPN client although I see that the OP uses the same configuration and it doesn’t work for him, which is very odd. Perhaps an Android or ROS update broke something with the cryptography techniques
Hi Bene007, can you share how can you connect with this configuration to strong swan? I need to keep this ipsec configuration, I can’t upgrade to version 7 for other vpn options, I need to stay on version 6, thanks
The most important settings, next to the correct server address and VPN type, are entering the correct algorithm (you need to check “Advanced settings”).
I guess you need to enter at the end of the settings the following: IKEv2 algorithm
aes256-sha256
@johnb175a, in your case, the VPN tunnel establishes, so the problem is somewhere else. That’s why I would additionally need a full export of the config:
Should I assign the IP to lo or create a bridge-loopback and assign it there? I was reading another article that seemed to indicate a bridge-loopback interface needed to be added with no members. It’s so strange that this all worked without all these changes a while back. Although I am not sure if it was working before I jumped to 7.x or after.
It’s one and the same. The lo interface was exposed precisely to eliminate the need for a loopback bridge
Quite odd indeed, although changes regarding IPsec were introduced, of which I’m not fully aware.
If @Sindy could also have a look at your case, maybe she would find something obvious that I may be missing because I’m not sure whether my suggestions would make a change in your situation
Ok, I applied all the changes you suggested but the problem persist. Any other things to try? I’m at a loss. It connects fine and passes traffic from the router and from machines behind the router to the android road warrior, but from the android road warrior to the router or anything behind it, nothing.
