HI all,
Spamhuas is blacklisted my server public IP and had to change it last month, and now it’s blacklisted again!
blacklisting my ip caused me some issues with annoying captcha that pop up every time i enter a site , blocking some connection to social apps (Yalla-Free voice chat roms) , even playstation4 had no access to the login page!
I can’t even post on mikrotik from that ip !
on spamhuas page i saw this :
New: many of these listings are caused by a MikroTik Router compromise. If you have a Microtik router, please consult this entry on the MikroTik Support Forum http://forum.mikrotik.com/t/advisory-vulnerability-exploiting-the-winbox-port-solved/118771/1
which leads to the Advisory: Vulnerability exploiting the Winbox port
My router already using 6.40.9 bugfix even before the blacklisting.
Any ideas to slove this (even if i changed the ip i’m afraid it will be blacklisted too)
Thanks for your replay,
I change the password frequently
No strange script ,No strange scheduler
IP > Socks is disabled
If you know other ways to disinfect the router please tell me.
disconnect router from Internet
review configuration
export configuration to file
netinstall
set new admin password
add new user with admin privileges
remove admin
import configuration
connect to Internet
I did that without a netinstall because the MT is way too far to reach my self.
In configuration the only thing that is abnormal to the common use is fetch to telegram bot url a lot, could that be causing the problem?
any other ideas?
The problem is I have an ISP With 600Mbps I can’t manually observe the traffic.
Can I just block a specific port or something that may send spam emails?
If you filter SMTP port, you could see if there comes packet trough ii in Winbox.
You could also log the Filer Rule to an external Syslog server like Splunk for deeper inspection.
