I recently experienced an unexpected reboot on one of our routers, a CCR1036-8G-2S+ (revision r2). It had been running normally but suddenly rebooted, leaving the following entries in the log upon startup:
router was rebooted without proper shutdown, probably kernel failurekernel failure in previous boot
Environment details:
Architecture: TILE (36 cores)
RouterOS: 6.49.19 (long-term)
Current Firmware (RouterBOOT): 6.43.5
Troubleshooting done so far:
I generated and uploaded the autosupout.rif to the MikroTik viewer portal, but there is no "Crash data" or kernel panic section available. It seems the crash was so sudden that the router couldn't write the memory dump.
I checked /system health and hardware sensors. Both dual PSUs are showing as ok with normal voltages, and temperatures are completely fine (CPU 48°C, board 29°C).
The remote syslog shows normal activity right until the drop, with no previous warnings, CPU spikes, or OOM errors.
I learned from the autosupout, that there is a gap between the RouterOS version (6.49.19) and the RouterBOOT firmware (6.43.5)...
My questions for the community:
Is this version mismatch between ROS and RouterBOOT a known cause for abrupt kernel panics on TILE architecture?
Has anyone experienced this specific behavior (no crash dump written) and solved it just by syncing the firmware?
Since this is an r2 board, I know it uses removable SODIMM DDR3 RAM. Should I consider this sudden panic as an early sign of failing RAM modules, or is the firmware mismatch the absolute main suspect here?
How many times it happend?
Once for how many years?
I would love a device that has 99.9999999999999999% uptime.
However you should have a valid backup and a spare device - even quite week comparing to 1036 - to be able to copy configuration and replace the 1036 in spite of anything. Slow connectivity is better than none. You should have replacement not because of this sudden reboot, you should have it as a "good admin".
This happened four times between January and March this year. I upgraded to the latest version of the OS, and it didn’t happen again until two days ago. This time, it only happened once.
I have all ports closed on my router, except for BGP to my peering provider and SSH and Winbox access through my VPN. So I would almost rule out an attack against any exposed service. The router typically runs at only 5–10% CPU utilization.
This is my BGP router, and yes, I have another CCR1036 as a backup, with a replica of the configuration, but it has de same version of firmware 6.43.5
If you have CCR1036, then feel free to update to the latest version 7.24.5 and everything will work. Ros and current (router boot firmware) must be the same. I have Ccr1009 and Ccr1036 routers in two companies. We have updated the ROS and also the system-routerbord (board) to the latest 7.24.5 and everything works very well.
Otherwise, there will be problems with system stability! It is 100% It is advisable to configure the firewall logic according to the following method - config firewall That's all and there will be no more router problems
And where does it say that?
I’ve been using CCR1036s since they first came out,
and they never crash on me, right now, they’re all updated to version 6.49.22 and working perfectly.
They ran on 6.48.7 for the two or three months that version was out, and never crashed then, either.
No, of course it's not 100% mandatory, but from what I've experienced in various cases, there have been problems not only with the Ros installation, but also with the firewall rules. Well, that's what happened in reality. Nothing personal
I have had similar cases, not specifically with the CCR1036, with other models and the problems have also been solved with a proper system update.... First Ros and then system-routerboard.
Advising someone who uses v6 for BGP to switch to v7, simply because "and everything will work",
would completely bring the network to a halt, given the changes required to get BGP running on v7.
Don't give haphazard advice, moving from v6 to v7 requires precise planning.
Of course,
if the setup consists of just a couple of firewall rules in the exact required order, switching to v7 doesn't make much difference...
So far, not a single test I’ve run to migrate from a BGP v6 machine to a v7 one has worked right away without requiring further tweaking.
The problem is that people shouldn't reply without first reading the rest of the topic...
at least when the topic is as short as this one...
Also, details should ideally be written right away or added to the first post,
but in this case, the problem is likely hardware rather than software.
It has happened to me before: you replace the capacitors, and everything goes back to working 100%
without changing the software or firmware, firewall rules or rules order...
I replaced them (6.49.22) for safety reasons, not because of any restarts (on 6.48.7).
''''''Check capacitors, the board is very old, how often do you open it to check capacitors inside?...''''''
This case has not happened in my practice yet, especially on the CCR series router. Okay, there have been problems with the RB750G, with the RB433 capacitors..... but that's all. Nothing personal, I just read the beginning of the topic and accordingly orient myself by this information. If I have had something similar, I share the information. That's all. Let's not get tied to specific protocols, etc. Ok, I agree, you are probably a much better specialist than me, but well...sorry, I just wanted to help a person, share my experience and hope that something from it will be useful to him.
Although I have no experience with the CCR1036-8G-2S+ (revision r2), @rextended's recommendation to inspect the capacitors is good advice. I have seen this problem affect other routers (from multiple vendors). And bad caps can cause "random" reboots, because RAM contents can get changed due to unstable voltage (voltage dips), especially when there is a larger load. See this google query what happens when an electorlytic capacitor bulges This showed up for me:
Power supplies stop working right, leading to voltage drops, strange device reboots, random computer lockups, or complete system failure. [1, 2]
For an example of what a leaking/bulging capacitor looks like see this post, or this google query bulging electrolytic capacitor
Since there is a spare, you may want to verify the caps in it, make sure it has the exact config as the original, than during scheduled outage (if possible), swap in the spare. Then examine the original's capacitors and replace the capacitors if needed.
