mysterious DNS issues. pingable but can't get a response
This could be a little bit complex network configuration. So let me begin with one diagram.
We have 3 offices that are in 3 different locations with mikrotik routers & internet connectivity.
And they have wireguard connections to 2 CHR routers (Office-1 & 2 to CHR router-2, and Office-1 &3 to CHR router-1)
We’re trying to create some standardized template (.rsc script) so we could deploy same configuration to other offices.
Let’s focus on Office-1, that’s the problem of the day. lol
The scenarios are as follows:
==Mikrotik Router==
  • two ether ports (ether1, ether2) that connects to two LANs: ether1: 192.168.1.0/24 & ether2: 192.168.2.0/24
  • one ether port(ether3) is connected to fiber ONT/ONU, using PPPoE dialups (pppoe-out1..8) connecting to WAN.
  • Wireguard is configured (wg-1, wg-2) to connect to CHR-1 & CHR-2, and an additional interface (wg-dialin) to allow dial-in (ie. VPN) users to access office resources.
  • With the connections to CHR-1 & CHR-2, Office-1 is able to reach Office-2 & Office-3’s 192.168.91.0/24, 192.168.92.0,24, 192.168.81.0/24, 192.168.82.0/24 via Wireguard connection.
  • the router will establish all PPPoE connections(pppoe-out1..8)to obtain 8 different public IPs.
  • the router will maintain a set of Address List (out-1..8) to mangle some connection from certain LAN IPs to go to WAN via a specific PPPoE connection (pppoe-out1..8 ). If not in Address List out-1..8, then use default main routing table.
  • the main routing table use pppoe-out1..8 as gateway with different distance assignment as fail-over.
To achieve those demands, here’s my strategy:
  • Define 3 additional address list: DialIn, LocalRealm, ForeignRealm. LocalRealm to define Office-1’s LAN subnets; ForeignRealm to define CHR subnets & LAN subnets in Office-2 & 3 (namely 172.31.32.0/24, 172.31.48.0/24, 192.168.91.0/24, 192.168.92.0/24, 192.168.81.0/24, 192.168.82.0/24).
  • In /ip firewall mangle, I add a chain called CheckRealm. If dst-address-list matches LocalRealm/ForeignRealm/DialIn, then return, ignore the subsequent mark-routing task; or assign them to out-1..8 if match Address List out-1..8. And if the connection is marked by input-1..8 by different incoming PPPoE-out1..8 connections. it will be marked as out-1..8 to make the data flow out to the originating connection.
  • As to NAT, only LocalRealm/ForeignRealm/DialIn to PPPoE connections(all-ppp) will perform srcnat.
I think I should cover most of edges…And I’ve come up with a configuration file to have all those in scripts.
Oddly enough, DNS doesn’t work at all.
I tried to ping an ip address from WAN (such as 8.8.8.8 ) it works.
[admin@MTx86@WY] > ping 8.8.8.8
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 8.8.8.8                                    56 118 2ms127us
    1 8.8.8.8                                    56 118 2ms47us
    2 8.8.8.8                                    56 118 2ms133us
    3 8.8.8.8                                    56 118 2ms145us
    4 8.8.8.8                                    56 118 2ms121us
    sent=5 received=5 packet-loss=0% min-rtt=2ms47us avg-rtt=2ms114us max-rtt=2ms145us
[admin@MTx86@WY] >
but if I try to ping www.google.com, it hangs for a while and responded with
[admin@MTx86@WY] > ping www.google.com
invalid value for argument address:
    invalid value of mac-address, mac address required
    invalid value for argument ipv6-address
    while resolving ip-address: could not get answer from dns server
[admin@MTx86@WY] >
What’s more strange is that, if I connect the mikrotik router’s WAN to an home router’s LAN port, instead of ONT/ONU, and configure WAN with dhcp-client, IT WILL WORK…!!
[admin@MTx86@WY] > ping dns.google
    0 8.8.8.8                                    56  53 17ms804us
    1 8.8.8.8                                    56  53 18ms458us
    2 8.8.8.8                                    56  53 17ms535us
    3 8.8.8.8                                    56  53 19ms712us
    4 8.8.8.8                                    56  53 17ms781us
    5 8.8.8.8                                    56  53 17ms751us
    sent=6 received=6 packet-loss=0% min-rtt=17ms535us avg-rtt=18ms173us max-rtt=19ms712us
[admin@MTx86@WY] >
I’m really confused…is there anything missing in my configuration…?
Do hope someone could shed some lights…
==Configuration==
set [ find default-name=ether1 ] comment="Local Network 192.168.1.0/24" \
    disable-running-check=no
set [ find default-name=ether2 ] comment="Local Network 192.168.2.0/24" \
set [ find default-name=ether3 ] comment="Connection to Fiber (PPPoE)" \
/interface wireguard
add listen-port=13229 mtu=1420 name=wg-dialin
add listen-port=13232 mtu=1420 name=wg-2
add listen-port=13231 mtu=1420 name=wg-1
add name=WireGuard
add name=WAN
add name=LAN
add name=pool-intra ranges=192.168.1.10-192.168.1.253
add address-pool=pool-intra interface=ether1 lease-time=1d name=dhcp-intra
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add change-tcp-mss=yes name=pppoe-out_default on-down="/interface set disabled\
    =yes [find name=\$interface]\r\
    \ndelay 20\r\
    \n/interface set disabled=no [find name=\$interface]\r\
    \n" use-compression=yes use-encryption=yes use-ipv6=no
/interface pppoe-client
add disabled=no interface=ether3 name=pppoe-out1 profile=pppoe-out_default \
    user=pppoeuser
add disabled=no interface=ether3 name=pppoe-out2 profile=pppoe-out_default \
    user=pppoeuser
add disabled=no interface=ether3 name=pppoe-out3 profile=pppoe-out_default \
    user=pppoeuser
add disabled=no interface=ether3 name=pppoe-out4 profile=pppoe-out_default \
    user=pppoeuser
add disabled=no interface=ether3 name=pppoe-out5 profile=pppoe-out_default \
    user=pppoeuser
add disabled=no interface=ether3 name=pppoe-out6 profile=pppoe-out_default user=\
    pppoeuser
add disabled=no interface=ether3 name=pppoe-out7 profile=pppoe-out_default user=\
    pppoeuser
add disabled=no interface=ether3 name=pppoe-out8 profile=pppoe-out_default user=\
    pppoeuser
/routing table
add disabled=no fib name=out-1
add disabled=no fib name=out-2
add disabled=no fib name=out-3
add disabled=no fib name=out-4
add disabled=no fib name=out-5
add disabled=no fib name=out-6
add disabled=no fib name=out-7
add disabled=no fib name=out-8
set discover-interface-list=all
/ip settings
set accept-redirects=yes accept-source-route=yes max-neighbor-entries=8192 \
    tcp-syncookies=yes
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no max-neighbor-entries=8192
add interface=wg-2 list=WireGuard
add interface=wg-1 list=WireGuard
add interface=wg-dialin list=WireGuard
add interface=pppoe-out2 list=WAN
add interface=pppoe-out3 list=WAN
add interface=pppoe-out4 list=WAN
add interface=pppoe-out5 list=WAN
add interface=pppoe-out6 list=WAN
add interface=pppoe-out7 list=WAN
add interface=pppoe-out8 list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
/interface wireguard peers
add allowed-address=172.31.48.0/24,192.168.81.0/24,192.168.82.0/24 comment=chr-2 endpoint-address=\
    somewhere.chr.router endpoint-port=13231 interface=wg-2 \
    persistent-keepalive=25s public-key=\
    "5YN3m9tWIdeW4zBa5oXe5EQAIFADiwJWup7PtHzCmjs="
add allowed-address=172.31.32.0/24,192.168.91.0/24,192.168.92.0/24 comment=chr-1 endpoint-address=\
    somewhere.chr2.router endpoint-port=13231 interface=wg-1 \
    "CnyQ9+yv9hd4y1wpr18wD6Ue1VjKz1rGkg4DNn5dZVE="
add allowed-address=\
    192.168.255.123/32 comment=jy interface=wg-dialin \
    "sj994QXhvmgucCv0kHnFx1CVEsD4vXE48AlRdOOdW20="
add allowed-address=192.168.255.253/32 comment=ych interface=\
    wg-dialin persistent-keepalive=25s public-key=\
    "wfYiug+5kjmvp5N4/5MoWvqgm3elgeE0URlCgBUniXo="
add address=192.168.255.254/24 interface=wg-dialin network=192.168.255.0
add address=172.31.32.140/24 interface=wg-1 network=172.31.32.0
add address=172.31.48.140/24 interface=wg-2 network=172.31.48.0
add address=192.168.1.254/24 interface=ether1 network=192.168.1.0
add address=192.168.2.254/24 interface=ether2 network=192.168.2.0
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.254 \
    ntp-server=216.239.35.8
set cache-size=8192KiB max-concurrent-queries=1000 \
    max-concurrent-tcp-sessions=2000 servers=168.95.1.1
/ip firewall address-list
add address=192.168.255.0/24 list=DialIn
add address=192.168.1.0/24 list=LocalRealm
add address=192.168.11.0/24 list=ForeignRealm
add address=192.168.34.0/24 list=ForeignRealm
add address=172.31.32.0/24 list=ForeignRealm
add address=172.31.48.0/24 list=ForeignRealm
add address=172.31.64.0/24 list=ForeignRealm
add address=172.31.240.0/24 list=ForeignRealm
add address=172.31.241.0/24 list=ForeignRealm
add action=drop chain=input comment="block port 445 SMB attack from WAN" \
    dst-port=445 in-interface=all-ppp protocol=tcp
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=input comment="Established, Related" \
add action=accept chain=forward comment="Established, Related" \
add action=jump chain=forward comment="DDoS detection" disabled=yes \
    in-interface-list=WAN jump-target=detect-ddos protocol=tcp
        add action=return chain=detect-ddos comment=\
            "Check if exceeding detection rate (SYN-ACK flood)" dst-limit=\
            32,32,src-and-dst-addresses/10s protocol=tcp tcp-flags=syn,ack
            "Check if exceeding detection rate" dst-limit=\
        add action=add-dst-to-address-list address-list=ddos-targets \
            address-list-timeout=10m chain=detect-ddos
        add action=add-src-to-address-list address-list=ddos-attackers \
add action=accept chain=input comment="Allow WireGuard UDP Ports" dst-port=\
    13229-13232 in-interface-list=WAN protocol=udp
add action=accept chain=forward comment="Allow DNS lookup" in-interface-list=\
    WAN protocol=udp src-port=53
add action=accept chain=input comment="Allow DNS lookup" in-interface-list=\
add action=add-src-to-address-list address-list=PortKnocking1 \
    address-list-timeout=30s chain=input comment=PortKnocking1 dst-port=1234 \
    in-interface=ether1 protocol=tcp
add action=add-src-to-address-list address-list=PortKnocking2 \
    address-list-timeout=30s chain=input comment=PortKnocking2 dst-port=2345 \
    protocol=tcp src-address-list=PortKnocking1
add action=add-src-to-address-list address-list=PortKnocking3 \
    address-list-timeout=30s chain=input comment=PortKnocking3 dst-port=3456 \
    protocol=tcp src-address-list=PortKnocking2
add action=add-src-to-address-list address-list=PortKnocking4 \
    address-list-timeout=30s chain=input comment=PortKnocking4 dst-port=4567 \
    protocol=tcp src-address-list=PortKnocking3
add action=add-src-to-address-list address-list=TrustedClient \
    address-list-timeout=2h chain=input comment=PortKnocking5 dst-port=5678 \
    protocol=tcp src-address-list=PortKnocking4
    "Accept Trusted Clients from PortKnocking Procedure" dst-port=22,443,8291 \
    protocol=tcp src-address-list=TrustedClient
add action=accept chain=input comment="Accept Trusted Clients from WireGuard" \
    dst-port=22,443,8291 in-interface-list=WireGuard protocol=tcp
add action=drop chain=input comment="Drop SSH/WinBox connection from IP addres\
    ses in Blockhole address list" dst-port=22,443,8291 \
    in-interface-list=WAN protocol=tcp src-address-list=Blackhole
add action=add-src-to-address-list address-list=Blackhole \
    address-list-timeout=2w6d chain=input comment=\
    "Blocked IP address that attempted multiple SSH connections" \
    connection-state=new dst-port=22,8291 protocol=tcp src-address-list=\
    ssh_attempt_3
add action=add-src-to-address-list address-list=ssh_attempt_3 \
    address-list-timeout=5m chain=input comment=\
    "IP address that attempted to create 3 SSH connections" connection-state=\
    new dst-port=22,8291 protocol=tcp src-address-list=ssh_attempt_2
add action=add-src-to-address-list address-list=ssh_attempt_2 \
    "IP address that attempted to create 2 SSH connections" connection-state=\
    new dst-port=22,8291 protocol=tcp src-address-list=ssh_attempt_1
add action=add-src-to-address-list address-list=ssh_attempt_1 \
    "IP address that attempted to create an SSH connections" \
    connection-state=new dst-port=22,8291 in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="allow dhcp request" dst-address=\
    255.255.255.255 dst-port=67 protocol=udp src-address=0.0.0.0 \
    src-address-list=LocalRealm src-port=68
add action=accept chain=input comment="Allow LocalRealm Input" \
    connection-state="" src-address-list=LocalRealm
add action=accept chain=input comment="Allow ForeignRealm Input" \
    connection-state="" src-address-list=ForeignRealm
add action=accept chain=input comment="Allow WireGuard Input" \
    connection-state="" in-interface-list=WireGuard
add action=accept chain=forward comment="Allow LocalRealm Forward" \
add action=accept chain=forward comment="Allow ForeignRealm Forward" \
add action=accept chain=forward comment="Allow WireGuard Forward" \
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
    protocol=icmp
        add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
            icmp
        add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
            protocol=icmp
        add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
            protocol=icmp
        add action=accept chain=icmp comment=\
            "host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
        add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
            protocol=icmp
        add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
            protocol=icmp
        add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
            protocol=icmp
        add action=drop chain=icmp comment="deny all other types"
add action=jump chain=input comment=\
    "intrusBL: Check for bad stuff in \"Attack\" chain" jump-target=Attacks
        add action=drop chain=Attacks comment=\
            "intrusBL: Drop connections FROM blacklisted hosts" src-address-list=\
            Blackhole
            "intrusBL: Drop connections TO blacklisted hosts" dst-address-list=\
            Blackhole
            "intrusBL: Invalid packets (No valid current connection)" \
            connection-state=invalid
        add action=drop chain=Attacks comment="intrusBL: Invalid TCP flag combo" \
            protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
            protocol=tcp tcp-flags=fin,syn
            protocol=tcp tcp-flags=fin,rst
            protocol=tcp tcp-flags=fin,!ack
            protocol=tcp tcp-flags=fin,urg
            protocol=tcp tcp-flags=syn,rst
            protocol=tcp tcp-flags=rst,urg
        add action=drop chain=Attacks comment="intrusBL: Invalid TCP source port (0)" \
            protocol=tcp src-port=0
            "intrusBL: Invalid TCP destination port (0)" dst-port=0 protocol=tcp
        add action=drop chain=Attacks comment="intrusBL: Invalid UDP source port (0)" \
            protocol=udp src-port=0
            "intrusBL: Invalid UDP destination port (0)" dst-port=0 protocol=udp
        add action=return chain=Attacks comment=\
            "intrusBL: Return to the chain that jumped"
        add action=passthrough chain=input comment=\
            "Below are Beginning of Attack Chain..."
    "intrusBL: Drop everything else by default(drop input to router)" \
    in-interface-list=WAN log=yes log-prefix=input: \
    protocol=tcp
    "Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat \
    connection-state=new in-interface=all-ppp log=yes log-prefix=!NAT
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes \
#mark connection
add action=mark-connection chain=prerouting in-interface=pppoe-out1 \
    connection-mark=no-mark new-connection-mark=input-1 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out2 \
    connection-mark=no-mark new-connection-mark=input-2 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out3 \
    connection-mark=no-mark new-connection-mark=input-3 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out4 \
    connection-mark=no-mark new-connection-mark=input-4 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out5 \
    connection-mark=no-mark new-connection-mark=input-5 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out6 \
    connection-mark=no-mark new-connection-mark=input-6 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out7 \
    connection-mark=no-mark new-connection-mark=input-7 passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-out8 \
    connection-mark=no-mark new-connection-mark=input-8 passthrough=yes
#if traffic is from LocalRealm->LocalRealm/ForeignRealm/DialIn, then return; DO NOT do mark-routing
add action=jump chain=output jump-target=CheckRealm
    add action=return chain=CheckRealm dst-address-list=LocalRealm
    add action=return chain=CheckRealm dst-address-list=ForeignRealm
    add action=return chain=CheckRealm dst-address-list=DialIn
    add action=mark-routing chain=CheckRealm new-routing-mark=out-1 passthrough=\
        no src-address-list=out-1
    add action=mark-routing chain=CheckRealm new-routing-mark=out-2 passthrough=\
        no src-address-list=out-2
    add action=mark-routing chain=CheckRealm new-routing-mark=out-3 passthrough=\
        no src-address-list=out-3
    add action=mark-routing chain=CheckRealm new-routing-mark=out-4 passthrough=\
        no src-address-list=out-4
    add action=mark-routing chain=CheckRealm new-routing-mark=out-5 passthrough=\
        no src-address-list=out-5
    add action=mark-routing chain=CheckRealm new-routing-mark=out-6 passthrough=\
        no src-address-list=out-6
    add action=mark-routing chain=CheckRealm new-routing-mark=out-7 passthrough=\
        no src-address-list=out-7
    add action=mark-routing chain=CheckRealm new-routing-mark=out-8 passthrough=\
        no src-address-list=out-8
    # mark-routing: coming from ppoe-outX (labeled input-x) => go back to pppoe-outX
    add action=mark-routing chain=CheckRealm connection-mark=input-1 \
        new-routing-mark=out-1 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-2 \
        new-routing-mark=out-2 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-3 \
        new-routing-mark=out-3 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-4 \
        new-routing-mark=out-4 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-5 \
        new-routing-mark=out-5 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-6 \
        new-routing-mark=out-6 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-7 \
        new-routing-mark=out-7 passthrough=no
    add action=mark-routing chain=CheckRealm connection-mark=input-8 \
        new-routing-mark=out-8 passthrough=no
add action=masquerade chain=srcnat out-interface-list=WAN src-address-list=\
    LocalRealm
    DialIn
    ForeignRealm
add action=masquerade chain=srcnat dst-address-list=ForeignRealm \
    src-address-list=DialIn
/ip firewall raw
add action=drop chain=prerouting comment="drop DDoS connections" \
    dst-address-list=ddos-targets src-address-list=ddos-attackers
#ForeignRealm=>go to CHR router
add disabled=no distance=1 dst-address=192.168.91.0/24 gateway=172.31.32.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=11
add disabled=no distance=1 dst-address=192.168.92.0/24 gateway=172.31.32.1 \
    target-scope=11
add disabled=no distance=1 dst-address=192.168.81.0/24 gateway=172.31.48.1 \
    target-scope=11
add disabled=no distance=1 dst-address=192.168.82.0/24 gateway=172.31.48.1 \
    target-scope=11
#for mark-routing
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 pref-src=\
    "" routing-table=out-1 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 pref-src=\
    "" routing-table=out-2 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out3 pref-src=\
    "" routing-table=out-3 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out4 pref-src=\
    "" routing-table=out-4 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out5 pref-src=\
    "" routing-table=out-5 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out6 pref-src=\
    "" routing-table=out-6 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out7 pref-src=\
    "" routing-table=out-7 scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out8 pref-src=\
    "" routing-table=out-8 scope=30 suppress-hw-offload=no target-scope=11
#main default route to pppoe-out1 then to out2,3,4,5...8 if unreachable.
    "" routing-table=main scope=30 suppress-hw-offload=no target-scope=11
add disabled=no distance=12 dst-address=0.0.0.0/0 gateway=pppoe-out2 \
    target-scope=10
add disabled=no distance=13 dst-address=0.0.0.0/0 gateway=pppoe-out3 \
    target-scope=10
add disabled=no distance=14 dst-address=0.0.0.0/0 gateway=pppoe-out4 \
    target-scope=10
add disabled=no distance=15 dst-address=0.0.0.0/0 gateway=pppoe-out5 \
    target-scope=10
add disabled=no distance=16 dst-address=0.0.0.0/0 gateway=pppoe-out6 \
    target-scope=10
add disabled=no distance=17 dst-address=0.0.0.0/0 gateway=pppoe-out7 \
    target-scope=10
add disabled=no distance=18 dst-address=0.0.0.0/0 gateway=pppoe-out8 \
    target-scope=10
add disabled=no distance=10 dst-address=172.31.32.0/24 gateway=wg-1 \
    routing-table=main scope=30 target-scope=10
add disabled=no distance=10 dst-address=172.31.48.0/24 gateway=wg-2 \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Taipei
/system hardware
set allow-x86-64=yes
/system identity
/system ntp client
set enabled=yes
/system ntp client servers
add address=216.239.35.0
add address=216.239.35.4
Sniff out DNS replies, see if a tool like Wireshark highlights obvious errors there.
mystery solved.
I just read two more similar posts with the same DNS issues.
Turns out that my router are running on the problematic v7.10.2 as well…
after downgrade to v7.9, everything worked as expected now…
God I spent a WHOLE WEEK questioning myself if I missed anything… :confused:
