How get value of the name[=value] into script ?
IE.
/ip address add address=$ipaddress interface=ether1
The line command:
myscript ip=192.168.0.2
(sorry for bad english)
IE.
The line command:
I don’t believe you can use arguments to a script. But you can assign global variables.
ie:
:global IPAddr 192.168.0.2
then
/ip address add address=$IPAddr interface=ether1
Does that help? :global variables live as long as the router is running. Once rebooted you lose them.
Would it be possible to have a startup script that we can set global variables into?
