hello
can you help me in this scenario
is there anyway to change order of nat before mangle operation
it means that i want to select output interface by mangles by destination IP after NAT Operation
thanks
hello
thanks
Hi ehsan , use packet marking , to my knowledge in mikrotik mangle is performed first ,
but what’s the logic behind this ?! interface will be automatically selected by router depends on your interfaces IP address , guys correct me if i’m wrong ,
thanks
thanks for reply
i use mangles for load balancing over two interface of my router and now i am using 2 old router one for NAT and other one for policy routing and load balancing .
i need to deploy this configuration on my core CCR router
it’s gonna be a complex configuration !!! could you send a diagram ? of course there is a tricky way
