After adding my nat statement my OSPF neighbor is lost. I have tried adding protocol=!ospf dst-address-type=unicast out-interface=ether1-gateway to my nat statement. I have also added 224.0.0.0/23 and 255.255.255.255 to the my_network address list. I have tried several router OS versions and different routerboard models.
My conclusion is the nat statement is matching the osfp traffic.
169.254.1.1 is not active on the network anywhere. Interface spf+1 is not active on this device or have an address or route associated. This rule does not match any traffic. The nat rules shows 0 bytes and 0 packets. Disabling the nat rule fixes ospf.
I have also tried adding the sugested "add chain=srcnat protocol=ospf action=accept " rule as the only rule. It breaks OSPF too.
log print:
17:14:53 system,info nat rule changed by admin
17:15:26 route,ospf,info OSPFv2 neighbor 10.108.255.254: state change from 2-Way t
o Init
17:15:27 route,ospf,info OSPFv2 neighbor 10.132.2.1: state change from 2-Way to In
it
17:15:27 route,ospf,info OSPFv2 neighbor 10.116.1.1: state change from 2-Way to In
it
17:15:27 route,ospf,info OSPFv2 neighbor 10.101.4.3: state change from 2-Way to In
it
17:15:29 route,ospf,info OSPFv2 neighbor 10.108.40.1: state change from 2-Way to I
nit
17:15:30 route,ospf,info OSPFv2 neighbor 10.101.255.255: state change from 2-Way t
o Init
17:15:30 route,ospf,info OSPFv2 neighbor 10.100.0.15: state change from 2-Way to I
nit
17:15:30 route,ospf,info OSPFv2 neighbor 10.101.4.39: state change from 2-Way to I
nit
17:15:33 route,ospf,info OSPFv2 neighbor 10.140.32.1: state change from 2-Way to I
nit
17:15:33 route,ospf,info OSPFv2 neighbor 10.102.8.1: state change from 2-Way to In
it
17:15:34 route,ospf,info OSPFv2 neighbor 10.140.60.1: state change from 2-Way to I
nit
17:15:34 route,ospf,info OSPFv2 neighbor 10.101.4.25: state change from 2-Way to I
nit
What I did was to add to the NAT rule:
protocol=!ospf
So, an example src nat rule may look like:
add action=src-nat chain=srcnat comment=“my new nat rule” protocol=!ospf src-address=192.168.88.0/24 to-address=192.168.1.11
This really threw me for a long while - If there is a better way to do this - please let me know, as I have very little mikrotik experience.
Confirmed. Just happened to me. Enabling any NAT rule changed the outbound IP OSPF was using, even if the NAT rule had nothing to do with that IP. Disabling the IP, removing it from OSPF networks, etc: nothing worked. Adding a raw rule to no-track the ospf protocol was the only way I could get it running again.
edit: this is on a CCR1009-7G-1C-1S+ running 6.48.1
The bug is till persistent in 6.49.5 and 7.1.5 -too. At our setup the firewall raw prerouting action does not work but adding a rule to output chain OSPF starts working …
Really annoying because the bug was not showing up in our 6.47.1 setup but after upgrading the software the bug showed up…
We are using OSPF and NAT on a router running Router OS v7.2.3. This was causing problems where NAT was changing the outbound OSPF IP Address to the IP address we were using to NAT customer traffic. We tried some of the suggestions in this post with varying degrees of success. Sometimes when we rebooted the router, all the OSPF neighbor states would be stuck at init. The fix for us was to disable connection tracking for OSPF using the Router OS code below.
The only working solution for me as well.
Annoying bug, i suspect it wasn’t reproducing in 6.49.2 since i didn’t had any issue before upgrading to 6.49.15.
Thanks @CCIS
