NATing for Updater-Project
Hello everyone,
I am delighted to be part of this forum and look forward to receiving your help and, in turn, helping others.
I purchased the MikroTik Cloud Router Switch 326-24G-2S+RM to try out a special project.
Unfortunately, I am still a little overwhelmed when it comes to the settings and rules that need to be created.
My project:
I would like to use a PC connected to port 24 of the switch to access devices connected to ports 1-10. The special thing is that all 10 devices have the same IP (192.168.123.16).
My idea would be to use NAT or something else to be able to access all 10 devices separately under “virtual” IPs.
For example: The PC wants to address device 3. It uses the IP 192.168.124.3 (for example, it can also be in the .123 network if that is easier). This is converted to 192.168.123.16 in RouterOS and sent only to port 3. 124.4 would then go to port 4, and so on.
Special thing: The IP addresses of the 10 devices cannot be changed, and only the IP address 192.168.123.16/24 is stored, with no gateway, etc.
The IP of the PC, etc. can be changed freely. The switch is also only for this purpose and can be completely reconfigured.
Do you have any idea how I can do this?
Many thanks in advance and best regards,
MatNu
What you're intending to do is not at all atypical. As far as I see, your scenario (along with the appropriate solution) was discussed here:
This also resulted in a general user guide for this. (Linked in the thread.)
