I recently bought the service from Ivacy VPN , but it seems I can’t use L2TP/IPSEC connect to it using RouterOS. However, iphone connect to them using L2TP/IPSEC have no issue at all. Using an Android phone connect via L2TP to them also have no issue. Using Windows 10 create direct VPN connection via L2TP/IPSEC also works without issue. Therefore, I can confirm Ivacy VPN has no problem on L2TP. So, there is got to be something do with RouterOS.
The setting is pretty generic on routerOS.
The debug log as below. I wonder if anyone can help? Thanks.
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug session 1 entering state: dead
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug tunnel 75 entering state: dead
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug tunnel 75 received no replies disconnecting
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Receive-Window-Size=4
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Assigned-Tunnel-ID=75
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet Vendor-Name=""MikroTik""
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Host-Name=""MikroTik""
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet Firmware-Revision=0x1
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Bearer-Capabilities=0x0
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Framing-Capabilities=0x1
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Protocol-Version=0x01:00
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Message-Type=SCCRQ
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet tunnel-id=0 session-id=0 ns=0 nr=0
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet sent control message to 103.46.141.189:1701 from 0.0.0.0:1701
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 4204d26c a9c7801f 4d5b675d d589769c 8551ac7f
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet d522b355 841570fd c1214610 da605b43 817a7b1f ce83b425 a7dec82a 385522ec
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08100501 8e0d40b3 00000054 6d7df2b2
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 1 times of 84 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 84 bytes from .240.130[500] to 103.46.141.189[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug encrypted.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug d589769c 8551ac7f
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug save IV for next:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug a4849cf2 ad521090
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug encrypted payload by IV:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 003a929a 6d69abc7 5532b726 33c4d723 5dfe8647 2c392d54
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug with key:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug encryption(3des)
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 01100001 f04265ed 39139397 47fd7213 82ac4140 e9899603
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0c000018 af55c107 1de5cdf0 36a96191 64066b77 02d90dfd 0000001c 00000001
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug pad length = 4
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug begin encryption.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug af55c107 1de5cdf0 36a96191 64066b77 02d90dfd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug HASH computed:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug hmac(hmac_sha1)
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 8e0d40b3 0000001c 00000001 01100001 f04265ed 39139397 47fd7213 82ac4140
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug HASH with:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug phase2 IV computed:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug hash(sha1)
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f 8e0d40b3
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug phase1 last IV:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug compute IV for phase2
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug Removing PH1...
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug an undead schedule has been deleted.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug Deleting a Ph2...
4/15/2018 14:36 Debug 10.0.1.1 l2tp ppp debug CN2Vpn: LCP down event in initial state
4/15/2018 14:36 Debug 10.0.1.1 l2tp ppp debug CN2Vpn: LCP lowerdown
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug session 1 entering state: stopping
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 103.46.141.189 notification message 14:NO-PROPOSAL-CHOSEN doi=1 proto_id=3 spi=05fefa3f(size=4).
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug succeed.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug seen nptype=11(notify) len=16
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug seen nptype=8(hash) len=24
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug begin.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug hash validated.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug ff153181 769ef11e db1d1827 f444ef6d b231d4b3
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 57041f44 00000010 00000001 0304000e 05fefa3f
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 05fefa3f 00000000 00000000
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug ff153181 769ef11e db1d1827 f444ef6d b231d4b3 00000010 00000001 0304000e
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 08100501 57041f44 0000004c 0b000018
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug decrypted.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug skip to trim padding.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug padding len=1
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0304000e 05fefa3f 00000000 00000000
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0b000018 ff153181 769ef11e db1d1827 f444ef6d b231d4b3 00000010 00000001
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug decrypted payload but not trimed.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0d288ef6 02b8b5cf
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug decrypted payload by IV:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug ca45f068 6f81c374
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug IV was saved for next processing:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f 57041f44
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet a21b1216 ca45f068 6f81c374
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f1d24615 df03ec09 ab12b8c4 057c698a 85570928 e2f1e7d8 3b3e9b5e d49f87ca
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08100501 57041f44 0000004c 1c090853
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug ===== received 76 bytes from 103.46.141.189[500] to .240.130[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 1f487b91
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet c867f4a2 b89dbd35 c0576cec 9c0891d4 396452c4 b81d6bdf dc551c3b e920c62a
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 6f694757 519e3b1b 6139e33a 665cf810 49651f40 690e6e98 a9da5c5f b3823fb3
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet bc9d9502 b2feb85d 948dc80c 6911a3c8 0ea75a2c 5abdde88 817ecd58 6d132536
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 43ecdb4d b694d643 3eb0192f 2981ce81 0201c508 fc219f09 cb2b614e 36848de4
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f40d8199 c22a7611 1317f27b 3a307c68 e3217e69 1a7398e5 d953d9b5 7762da45
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 9251cc5d a5d4d156 cd715d18 53f9e024 eabd5a21 210cc605 739b5120 f69c6642
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 0200df4f dc721e12 cdea1f97 48674590 d249570e f563a354 6d51fe07 bcbee735
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 69a65a27 42f28097 43ec7aa0 9f903a51 59237134 3a9f0a37 4497957d 580abb5e
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08102001 ab17c348 00000124 05b21f85
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 1 times of 292 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 292 bytes from .240.130[500] to 103.46.141.189[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug e920c62a 1f487b91
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 4f51f89e f3b15846
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 672e8dbd efdc9303
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 35bcb376 fa4a25e4 5db89d9a 0500000c 011106a5 3deff082 0000000c 011106a5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug f375fb92 2fe38303 7a7f504f 8db8367a db014a1d fc409871 6398f402 8b45476b
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 332e9e7e 945800e1 f57df507 05a7a2f9 615e33b3 f5c6aaf1 eef1d6ce f5ddb79b
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 51c3fa32 4142afdb f840dbf3 0e6a89ce ce0467fd a4d5e235 27c7ddb5 267acbdf
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug e794292a 75ef459e 05000084 b02ccfd7 5b85d8d4 3adf1351 0563d4ee aa20800a
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 80040002 80050002 80030002 0400001c e0777ebd 0debf1f9 c19666bb 7c93e299
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 00000001 00000028 01030401 05fefa3f 0000001c 01030000 80010001 80020708
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 01000018 fb564a42 6795f7a2 b42eca4c b1ecf0c3 e488a92a 0a000034 00000001
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 20 next type 1
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug fb564a42 6795f7a2 b42eca4c b1ecf0c3 e488a92a
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 3deff082 0000000c 011106a5 672e8dbd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug fc409871 6398f402 8b45476b 35bcb376 fa4a25e4 5db89d9a 0500000c 011106a5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug f5c6aaf1 eef1d6ce f5ddb79b f375fb92 2fe38303 7a7f504f 8db8367a db014a1d
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug a4d5e235 27c7ddb5 267acbdf 332e9e7e 945800e1 f57df507 05a7a2f9 615e33b3
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 3adf1351 0563d4ee aa20800a 51c3fa32 4142afdb f840dbf3 0e6a89ce ce0467fd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0debf1f9 c19666bb 7c93e299 e794292a 75ef459e 05000084 b02ccfd7 5b85d8d4
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 01030000 80010001 80020708 80040002 80050002 80030002 0400001c e0777ebd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug ab17c348 0a000034 00000001 00000001 00000028 01030401 05fefa3f 0000001c
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 8 next type 0
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 8 next type 5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 128 next type 5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 24 next type 4
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug add payload of len 48 next type 10
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 011106a5 672e8dbd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug IDcr:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 011106a5 3deff082
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug IDci:
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug use remote ID type IPv4_address
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug use local ID type IPv4_address
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 8db8367a db014a1d fc409871 6398f402 8b45476b 35bcb376 fa4a25e4 5db89d9a
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 05a7a2f9 615e33b3 f5c6aaf1 eef1d6ce f5ddb79b f375fb92 2fe38303 7a7f504f
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0e6a89ce ce0467fd a4d5e235 27c7ddb5 267acbdf 332e9e7e 945800e1 f57df507
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug b02ccfd7 5b85d8d4 3adf1351 0563d4ee aa20800a 51c3fa32 4142afdb f840dbf3
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug compute DH's public.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 97015a45 7ab55789 de409aa0 55c43e39 3e98cbe0 d53f257a f29ba847 ab4b7ae7
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 173fc459 81110885 7ff65efe 472e26ef 6fae4d23 9448085d 4c47d86e 4b96a6d1
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 3cdb3a8c c8fec27c deabae01 2d403dac 3f283b86 2926af34 0645efae 6e06f256
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 7a147cc5 c28f3ae6 b82e757f bffd0cc5 fed00a8b 2564afc6 063420ae 24d11c93
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug compute DH's private.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug dh(modp1024)
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug pfkey getspi sent.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug pfkey GETSPI sent: ESP/Transport 103.46.141.189[500]-> .240.130[500]
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug call pfkey_send_getspi 1939b8b0
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f ab17c348
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug begin QUICK mode.
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=Transport reqid=0:0)
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug tunnel 75 entering state: wait-ctl-reply
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug tunnel 74 entering state: dead
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug tunnel 74 received no replies disconnecting
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 103.46.141.189 notification message 14:NO-PROPOSAL-CHOSEN doi=1 proto_id=3 spi=03f298fd(size=4).
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 383acd7a e9ff6d23 1a5dd34b 8d757878 c43ba8ea
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0c30899f 00000010 00000001 0304000e 03f298fd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 03f298fd 00000000 00000000
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 383acd7a e9ff6d23 1a5dd34b 8d757878 c43ba8ea 00000010 00000001 0304000e
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 08100501 0c30899f 0000004c 0b000018
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0304000e 03f298fd 00000000 00000000
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0b000018 383acd7a e9ff6d23 1a5dd34b 8d757878 c43ba8ea 00000010 00000001
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 7c335ac4 80597584
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug d32358fb 493740ff
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f 0c30899f
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet c1872f69 d32358fb 493740ff
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet db910207 1eb2e7f8 0ade8374 f9aa129d a6fdc2ac 82e760f1 a93bc389 7b55e2ad
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08100501 0c30899f 0000004c 51fa6939
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet ae6fdea5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet ea450008 a9e58ea1 1c3c5af3 1ac9c6be 6fbfe06f 17c3b052 d20ba4b7 d57e6b7e
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 65d72847 69915272 dda5e76a 517f4a8b 475c8258 a113d12d ae3e46a0 3d021d02
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 4ed24e9f 857c8737 9d793e0d f36a70ec f2cf4e57 5e320376 aee103f4 f1c03046
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet ae018e20 28e99b74 f56a0ba6 47fab4f3 c9a14c3b 9a5205aa 463a6d16 1e96f577
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 710e93b2 6be5f731 4ce8e5ab ad07dc90 738f9b9a 4ce4ef0d 16c2fa87 cb561c46
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 7d8d65b2 fe11da86 eabf758d e208e6f6 c3e8154e a49298f9 3d37c3c0 ca19dcd1
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 26ff6265 7052d7cb 4341c77b c7b6c515 0d23acf9 c240f3de 34a22dc1 175c0612
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 42530064 eb83ff01 dc48b30a 9fb03b7a 185cf737 26d24b63 d9fa9d69 6186bc33
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08102001 e70051f0 00000124 962c87a5
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 292 bytes from 240.130[500] to 103.46.141.189[500]
4/15/2018 14:36 Debug 10.0.1.1 l2tp debug packet (M) Assigned-Tunnel-ID=74
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 3ce52080 1c4103ed 764840e9 cce0aebe 19f7bc80
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug bd39cb76 00000010 00000001 0304000e 03f298fd
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 3ce52080 1c4103ed 764840e9 cce0aebe 19f7bc80 00000010 00000001 0304000e
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 08100501 bd39cb76 0000004c 0b000018
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 0b000018 3ce52080 1c4103ed 764840e9 cce0aebe 19f7bc80 00000010 00000001
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 7ed31706 8cc48fac
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug 595e5a4b 982fa8f7
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f bd39cb76
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 17d6e5bc 595e5a4b 982fa8f7
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet 2e818280 c8b93c5f 9c03e89f 173a96e0 223059ff 1209bd89 90c5b117 9d3ac6e1
4/15/2018 14:36 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08100501 bd39cb76 0000004c 57433cc6
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Receive-Window-Size=4
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Assigned-Tunnel-ID=74
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet Vendor-Name=""MikroTik""
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Host-Name=""MikroTik""
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet Firmware-Revision=0x1
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Bearer-Capabilities=0x0
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Framing-Capabilities=0x1
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Protocol-Version=0x01:00
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet (M) Message-Type=SCCRQ
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet tunnel-id=0 session-id=0 ns=0 nr=0
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug packet sent control message to 103.46.141.189:1701 from 0.0.0.0:1701
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 103.46.141.189 notification message 14:NO-PROPOSAL-CHOSEN doi=1 proto_id=3 spi=03f298fd(size=4).
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug succeed.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=11(notify) len=16
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=8(hash) len=24
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug begin.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug hash validated.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug cecc1c6a 589977ac 4dfdd0e2 44d7cc0e c1b23f93
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug HASH computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug hmac(hmac_sha1)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 5148a787 00000010 00000001 0304000e 03f298fd
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug HASH with:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 03f298fd 00000000 00000000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug cecc1c6a 589977ac 4dfdd0e2 44d7cc0e c1b23f93 00000010 00000001 0304000e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 08100501 5148a787 0000004c 0b000018
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug decrypted.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug skip to trim padding.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug padding len=1
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0304000e 03f298fd 00000000 00000000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0b000018 cecc1c6a 589977ac 4dfdd0e2 44d7cc0e c1b23f93 00000010 00000001
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug decrypted payload but not trimed.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 7e8e2e45 9c0fe6df
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug decrypted payload by IV:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 003a929a 6d69abc7 5532b726 33c4d723 5dfe8647 2c392d54
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug with key:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug encryption(3des)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 61dae7ae 7d35dde9
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug IV was saved for next processing:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug phase2 IV computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug hash(sha1)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f 5148a787
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug phase1 last IV:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute IV for phase2
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 419d8608 61dae7ae 7d35dde9
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 60430fbe b8e93d61 2cedf7e7 885f7ae6 190f837c 3898bb0c dcbda0b8 c5a34a44
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08100501 5148a787 0000004c a8f9e5ec
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ===== received 76 bytes from 103.46.141.189[500] to .240.130[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet ae6fdea5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet ea450008 a9e58ea1 1c3c5af3 1ac9c6be 6fbfe06f 17c3b052 d20ba4b7 d57e6b7e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 65d72847 69915272 dda5e76a 517f4a8b 475c8258 a113d12d ae3e46a0 3d021d02
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 4ed24e9f 857c8737 9d793e0d f36a70ec f2cf4e57 5e320376 aee103f4 f1c03046
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet ae018e20 28e99b74 f56a0ba6 47fab4f3 c9a14c3b 9a5205aa 463a6d16 1e96f577
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 710e93b2 6be5f731 4ce8e5ab ad07dc90 738f9b9a 4ce4ef0d 16c2fa87 cb561c46
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 7d8d65b2 fe11da86 eabf758d e208e6f6 c3e8154e a49298f9 3d37c3c0 ca19dcd1
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 26ff6265 7052d7cb 4341c77b c7b6c515 0d23acf9 c240f3de 34a22dc1 175c0612
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 42530064 eb83ff01 dc48b30a 9fb03b7a 185cf737 26d24b63 d9fa9d69 6186bc33
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 08102001 e70051f0 00000124 962c87a5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 1 times of 292 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 292 bytes from 240.130[500] to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug encrypted.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug d57e6b7e ae6fdea5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug save IV for next:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 3cedb79d 87e786c2
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug encrypted payload by IV:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 672e8dbd cbabe003
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 2a36b570 f8bba284 74ef2eff 0500000c 011106a5 3deff082 0000000c 011106a5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ecab2c46 dca9b5b4 b9face02 48a0cb20 d6cae1cc a704c14d 379d72b3 e0685c76
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 49e47f26 3d1f1818 13b203f5 2bda5bad ac6bcd72 3c3da900 7f562f95 b8c82378
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ed05a79e 7d069bd5 69c9c277 5bbb0099 ec91d609 75bae979 97de562f 4108af0a
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug c7c660ea c0bd3df5 05000084 71b93f89 0e43e184 1035553e 151f5ee6 6552f562
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 80040002 80050002 80030002 0400001c c77cb370 514777e3 b1de1b04 9551fffb
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 00000001 00000028 01030401 03f298fd 0000001c 01030000 80010001 80020708
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 01000018 da0b1176 9d88f388 18b748f9 c2dd939e e41d5dba 0a000034 00000001
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug pad length = 4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug begin encryption.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 20 next type 1
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug da0b1176 9d88f388 18b748f9 c2dd939e e41d5dba
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 3deff082 0000000c 011106a5 672e8dbd
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug a704c14d 379d72b3 e0685c76 2a36b570 f8bba284 74ef2eff 0500000c 011106a5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 3c3da900 7f562f95 b8c82378 ecab2c46 dca9b5b4 b9face02 48a0cb20 d6cae1cc
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 75bae979 97de562f 4108af0a 49e47f26 3d1f1818 13b203f5 2bda5bad ac6bcd72
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 1035553e 151f5ee6 6552f562 ed05a79e 7d069bd5 69c9c277 5bbb0099 ec91d609
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 514777e3 b1de1b04 9551fffb c7c660ea c0bd3df5 05000084 71b93f89 0e43e184
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 01030000 80010001 80020708 80040002 80050002 80030002 0400001c c77cb370
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug e70051f0 0a000034 00000001 00000001 00000028 01030401 03f298fd 0000001c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 8 next type 0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 8 next type 5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 128 next type 5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 24 next type 4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 48 next type 10
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 011106a5 672e8dbd
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug IDcr:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 011106a5 3deff082
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug IDci:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug use remote ID type IPv4_address
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug use local ID type IPv4_address
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 48a0cb20 d6cae1cc a704c14d 379d72b3 e0685c76 2a36b570 f8bba284 74ef2eff
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 2bda5bad ac6bcd72 3c3da900 7f562f95 b8c82378 ecab2c46 dca9b5b4 b9face02
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 5bbb0099 ec91d609 75bae979 97de562f 4108af0a 49e47f26 3d1f1818 13b203f5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 71b93f89 0e43e184 1035553e 151f5ee6 6552f562 ed05a79e 7d069bd5 69c9c277
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute DH's public.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 6b7af645 54b4bea8 d71b2353 5989a0bd 23921a4a f9705b62 5fad2fce 068e2a05
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug d1f8ae7f 91f7779b d128155b 346736cc 3d2895e2 8e4be150 56e1f98a 104cbfcc
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 7191d798 685f383e bfb7fda4 eb744d4f cc34cc5b 4088f70b 87d8466e 60e0d90f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 47fb9f58 d804b73f ea5c1d12 00013736 1f606214 68606fc1 0c721b02 e4cf9710
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute DH's private.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug dh(modp1024)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug pfkey getspi sent.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug pfkey GETSPI sent: ESP/Transport 103.46.141.189[500]-> .240.130[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug call pfkey_send_getspi f3a1c1f8
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug c8a57415 7ef44e4f e70051f0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug begin QUICK mode.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 01000000 672e8dbd
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 103.46.141.189 peer's ID:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug HASH for PSK validated.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug e4409cfd 55b1aa30 9a9725c6 e48e6b5e e07afcd0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 800b0001 000c0004 00015180 80010005 80030001 80020002 80040002 01000000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 00015180 80010007 800e0080 80030001 80020002 80040002 00000024 04010000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 800e00c0 80030001 80020002 80040002 03000028 03010000 800b0001 000c0004
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 80020002 80040002 03000028 02010000 800b0001 000c0004 00015180 80010007
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 03000028 01010000 800b0001 000c0004 00015180 80010007 800e0100 80030001
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 47fd7213 82ac4140 f04265ed 39139397 00000001 00000001 000000a4 01010004
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 526125a0 0761dca1 c80844f4 d08f4e76 ab7f78d5 c3b404e2 e26180f7 9f3f441c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug eee7217b 269e817c 3c9a15b3 995d5b25 f58b3f03 e5d0d981 f27c3321 ca38d933
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 073cb208 51052d58 e8c5f087 94045a72 45ed3589 5203d096 2df5fad2 05d80d90
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug d080a9f0 ebb41e23 17618033 8614c87b 5d928ded 6fb6ba5d 4ec9281d 2770e935
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ee78a126 1c552d73 1564299a a5efe86e 7586cc63 b4550d48 c2bc657f 3f40b32f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug b44718e4 8a3d3461 0b1f4ac7 46e7df65 d34188e8 b314fae2 3d41fabd 108b2060
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 394cf2ed 7ce53f4d 2ea8f113 acad88c3 853f0c08 575e9db9 097167b8 82ff7a35
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 7e601e84 39a29efe e4591af6 ce30f77e fb7f9b27 17519b2c 8490c09b 195bc9ac
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug HASH received:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=5(id) len=12
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 00000000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 01000000 672e8dbd 00000018 e4409cfd 55b1aa30 9a9725c6 e48e6b5e e07afcd0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 05100201 00000000 00000044 0800000c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug e07afcd0 00000000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0800000c 01000000 672e8dbd 00000018 e4409cfd 55b1aa30 9a9725c6 e48e6b5e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 295072af 79b9a37f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 7ef44e4f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet d0f062d4 99608584 8d81880d 2b94194f 2a0e7180 b61df1b1 241a3c71 c8a57415
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 05100201 00000000 00000044 b8eabe79
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ===== received 68 bytes from 103.46.141.189[500] to 240.130[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 79b9a37f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 0e7701bb e46cdffb 047dc2e7 b5d7b131 38c8c441 f5ecc67a 93251d16 295072af
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 05100201 00000000 00000044 531b0ddb
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 1 times of 68 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 68 bytes from .240.130[500] to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0ecf3bbf 1d245e92
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 568ef5ec a899c803
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0800000c 011101f4 3deff082 00000018 ad26b485 048762f1 198912d9 b2547c0d
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 20 next type 0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 8 next type 8
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ad26b485 048762f1 198912d9 b2547c0d 568ef5ec
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 800b0001 000c0004 00015180 80010005 80030001 80020002 80040002 011101f4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug f04265ed 39139397 47fd7213 82ac4140 00000001 00000001 000000a4 01010004
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug use ID type of IPv4_address
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug IV computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug final encryption key computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 2c392d54 ef96a619 35cea8ef 47596551 e73a8714
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute intermediate encryption key K2
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute intermediate encryption key K1
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug len(SKEYID_e) < len(Ka) (20 < 24) generating long key (Ka = K1 | K2 | ...)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug c75cea39 906e4b24 87d8b08a 3b2354fd 8d5ec4a9
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug SKEYID_e computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ef8b8559 c2bbd45d e55441ca b33e109b 80ea1e88
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug SKEYID_a computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug b5c7cdb4 cd052f9b 06bec041 fa4efdc0 a1487445
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug SKEYID_d computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 429f06c2 7e874633 73cd3c33 90f62e0e 50390c4c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug SKEYID computed:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 5f9a983b 4ff411a2 4050c18b 4ec8b01c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 3b51ff05 8565ea61 40366534 8292458c a3b6307f 91d3f52b 498eeadc 4401dfd4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug nonce 2:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug a299371b fafb5da8 5bbdd0ba 7aaf27ef 85472b8a 60bb6c1a
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug nonce 1:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug f9717f20 2a4b560b a4366ee3 f2df9eaf a8f4b9d7 06bf6fa7 627fe00f 9eff41a5
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 20d567c8 b6a44292 31927916 9f3b37e2 76969120 190976dc c922a9f7 69ed9ed2
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0fc187c6 e8dca1db 384f061b 4ef39d6d a4f42c72 b87f9557 5e287410 7a22d0ad
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 87835ed9 012e5356 513ecbb2 12256dd8 3144e05c ae49ba45 1593ca45 e11631c4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug compute DH's shared.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=20(nat-d) len=24
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=10(nonce) len=52
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=4(ke) len=132
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 3ad6813e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 1f08971e 8d1b17f7 77b9ed81 00000018 13932b07 ec06c491 6ee2aa4d 37aaab05
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 4401dfd4 5f9a983b 4ff411a2 4050c18b 4ec8b01c 14000018 b6a1e5ed 4d262c4e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 14000034 3b51ff05 8565ea61 40366534 8292458c a3b6307f 91d3f52b 498eeadc
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet ee78a126 1c552d73 1564299a a5efe86e 7586cc63 b4550d48 c2bc657f 3f40b32f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet b44718e4 8a3d3461 0b1f4ac7 46e7df65 d34188e8 b314fae2 3d41fabd 108b2060
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 394cf2ed 7ce53f4d 2ea8f113 acad88c3 853f0c08 575e9db9 097167b8 82ff7a35
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 7e601e84 39a29efe e4591af6 ce30f77e fb7f9b27 17519b2c 8490c09b 195bc9ac
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 04100200 00000000 00000104 0a000084
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ===== received 260 bytes from 103.46.141.189[500] to 240.130[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 13932b07 ec06c491 6ee2aa4d 37aaab05 3ad6813e 00000018 b6a1e5ed 4d262c4e
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 1400001c a299371b fafb5da8 5bbdd0ba 7aaf27ef 85472b8a 60bb6c1a 14000018
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 526125a0 0761dca1 c80844f4 d08f4e76 ab7f78d5 c3b404e2 e26180f7 9f3f441c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet eee7217b 269e817c 3c9a15b3 995d5b25 f58b3f03 e5d0d981 f27c3321 ca38d933
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 073cb208 51052d58 e8c5f087 94045a72 45ed3589 5203d096 2df5fad2 05d80d90
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet d080a9f0 ebb41e23 17618033 8614c87b 5d928ded 6fb6ba5d 4ec9281d 2770e935
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 04100200 00000000 000000ec 0a000084
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 1 times of 236 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 236 bytes from .240.130[500] to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 20 next type 20
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 24 next type 20
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 128 next type 10
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 82dea3f9 24152e5c 68470a2c c6269940 c8c3ee07 00d39247 ceaa2c49 9effcde3
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 71db9695 30609efc 46386fc7 b20f6533 91e3fe0f bb95c1bf 518fa64c 946647ad
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug b186edd0 455321c8 d0a39fd6 d1caac4c 1a8a62e8 6ab6f482 81d83b50 d2e3a551
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 67e78aec 5418b895 fdab6d46 bce7c43e ad010a17 30291220 e9c4b982 750c98cf
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug agreed on pre-shared key auth.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug an acceptable proposal found.
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug dh_group = 1024-bit MODP group:1024-bit MODP group
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug authmethod = pre-shared key:pre-shared key
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug hashtype = SHA:SHA
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (encklen = 0:0)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug enctype = 3DES-CBC:3DES-CBC
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (lifebyte = 0:0)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (lifetime = 86400:86400)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug Compared: Local:Peer
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (encklen = 128:0)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug enctype = AES-CBC:3DES-CBC
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (encklen = 192:0)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (encklen = 256:0)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Life Duration flag=0x0000 lorv=4
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Life Type flag=0x8000 lorv=seconds
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Authentication Method flag=0x8000 lorv=pre-shared key
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Group Description flag=0x8000 lorv=1024-bit MODP group
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Hash Algorithm flag=0x8000 lorv=SHA
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug type=Encryption Algorithm flag=0x8000 lorv=3DES-CBC
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug trns#=4 trns-id=IKE
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug prop#=1 prot-id=ISAKMP spi-size=0 #trns=1
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug proposal #1: 1 transform
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 0x80b3788: next=(nil) tnext=(nil)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug pair 1:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug transform #4 len=36
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=3(trns) len=36
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug proposal #1 len=44
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=2(prop) len=44
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 80040002 80030001 800b0001 000c0004 00015180
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 00000001 00000001 0000002c 01010001 00000024 04010000 80010005 80020002
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug total SA len=52
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug e3a5966a 76379fe7 07228231 e5ce8652
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug received unknown Vendor ID
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug fb1de3cd f341b7ea 16b7e5be 0855f120
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=13(vid) len=20
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=13(vid) len=24
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug seen nptype=1(sa) len=56
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet e3a5966a 76379fe7 07228231 e5ce8652
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 25e7de7f 00d6c2d3 0d000014 fb1de3cd f341b7ea 16b7e5be 0855f120 00000014
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 0d000014 90cb8091 3ebb696e 086381b5 ec427b1f 0d000014 4048b7d5 6ebce885
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 7c96fcbf b587e461 00000008 0d000014 4a131c81 07035845 5c5728f2 0e95452f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 80040002 80030001 800b0001 000c0004 00015180 0d000018 1e2b5169 05991c7d
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 00000001 00000001 0000002c 01010001 00000024 04010000 80010005 80020002
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 47fd7213 82ac4140 01100200 00000000 000000d0 0d000038
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug ===== received 208 bytes from 103.46.141.189[500] to .240.130[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet afcad713 68a1f1c9 6b8696fc 77570100
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 0be8a846 9579ddcc 0d000014 12f5f28c 457168a9 702d9fe2 74cc0100 00000014
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 0d000014 16f6ca16 e4a4066d 83821a0f 0aeaa862 0d000014 4485152d 18b6bbcd
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 35df21f8 7cfdb2fc 68b6a448 0d000014 90cb8091 3ebb696e 086381b5 ec427b1f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet e952fa6b 0d000014 7d9419a6 5310ca6f 2c179d92 15529d56 0d000014 cd604643
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 80d0bb3d ef54565e e84645d4 c85ce3ee 0d000014 9909b64e ed937c65 73de52ac
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 7737ae22 eab8f582 0d000014 4d1e0e13 6deafa34 c4f3ea9f 02ec7285 0d000014
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 0d000014 8f8d8382 6d246b6f c7a8a6a4 28c11de8 0d000014 439b59f8 ba676c4c
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 80030001 80020002 80040002 0d000014 4a131c81 07035845 5c5728f2 0e95452f
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 80020002 80040002 00000024 04010000 800b0001 000c0004 00015180 80010005
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 03000028 03010000 800b0001 000c0004 00015180 80010007 800e0080 80030001
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 800b0001 000c0004 00015180 80010007 800e00c0 80030001 80020002 80040002
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 00015180 80010007 800e0100 80030001 80020002 80040002 03000028 02010000
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet 00000001 00000001 000000a4 01010004 03000028 01010000 800b0001 000c0004
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug packet f04265ed 39139397 00000000 00000000 01100200 00000000 000001d0 0d0000b0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 1 times of 464 bytes message will be sent to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug 464 bytes from .240.130[500] to 103.46.141.189[500]
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 16 next type 0
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 16 next type 13
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug add payload of len 172 next type 13
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug f04265ed39139397
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug new cookie:
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
4/15/2018 14:35 Debug 10.0.1.1 ipsec debug (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=Transport reqid=0:0)
4/15/2018 14:35 Debug 10.0.1.1 l2tp debug tunnel 74 entering state: wait-ctl-reply
