Need Help On WDS!
how do i set up wds(dynamic) if i had more than 1 bridge with own vlan id on each bridge? by right i can only added 1 bridge on wds but now i need both vlan on wds mode(roaming)
bridge1: ether1, wlan1
bridge2: vlan201, vap1
bridge3: vlan104, vap2
thanks in advance
If you want 2 vlan in one vap, put 2 vlan interfaces in the vap.. You can put same vlan number to both interfaces if you need it.
