Need help with policy based routing and VPN
I’m trying to do something similar to what is described here - http://wiki.mikrotik.com/wiki/Policy_Base_Routing The sites in Address List called rcn should go through the VPN, everything else is routed through ether1.
The address list exists and shows proper values:
#   LIST                      ADDRESS                                        TIMEOUT
 0   ;;; RCN Blacklist
     rcn                       195.82.146.214
 1   rcn                       108.174.10.10
 2   rcn                       23.22.128.188
But it doesn’t work for me for some reason.
I set up an L2TP VPN client which works fine when I have the “Add default route” option enabled, but in this case everything goes through the VPN interface, of course. If I remove the option, the sites I want to access via VPN become unreachable in a weird way - I can ping them and traceroute shows that packets go through the VPN, but I cannot reach them using the browser.
Here are my settings:
The NAT rules:
0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
 1  D ;;; upnp 192.168.88.252: Skype UDP at 192.168.88.252:32453 (3611)
      chain=dstnat action=dst-nat to-addresses=192.168.88.252 to-ports=32453
      protocol=udp dst-address=192.168.100.14 in-interface=ether1
      dst-port=32453
 2  D ;;; upnp 192.168.88.252: Skype TCP at 192.168.88.252:32453 (3611)
      protocol=tcp dst-address=192.168.100.14 in-interface=ether1
      dst-port=32453
3    ;;; Masquerade for L2TP
      chain=srcnat action=masquerade out-interface=HMA_L2TP log=no
      log-prefix=""
The Mangle rules:
0  D ;;; special dummy rule to show fasttrack counters
      chain=prerouting action=passthrough
 1  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting action=passthrough
 3    ;;; Mark for L2TP
      chain=prerouting action=mark-routing new-routing-mark=L2TP
      passthrough=yes src-address=192.168.88.2-192.168.88.254
      dst-address-list=rcn log=yes log-prefix="rcn"
The routing table (the gateway HMA_L2TP is displayed as reachable):
1 A S  0.0.0.0/0                          HMA_L2TP                  1
 2 ADS  0.0.0.0/0                          192.168.100.1             1
 3 ADC  10.200.24.1/32     10.200.25.3     HMA_L2TP                  0
 4 ADC  192.168.88.0/24    192.168.88.1    bridge                    0
 5 ADC  192.168.100.0/24   192.168.100.14  ether1                    0
When I enable the “Add default gateway” option, everything works, and the routing table looks like this:
 1 ADS  0.0.0.0/0                          10.200.24.1               0
 2  DS  0.0.0.0/0                          192.168.100.1             1
 3 ADC  10.200.24.1/32     10.200.25.5     HMA_L2TP                  0
 4 ADS  72.8.134.120/32                    192.168.100.1             0
 5 ADC  192.168.88.0/24    192.168.88.1    bridge                    0
 6 ADC  192.168.100.0/24   192.168.100.14  ether1                    0
Like I said, I cannot reach the sites in the address list - they either fail to load after a timeout, or more weirdly, go through ether1 like there’s no VPN.
The log shows that and ACK and SYN are sent properly, through the VPN interface, the Masquerade rule works, but after a minute or so and ACK, RST is sent and everything stops.
The VPN has dynamic IP address, so I cannot just write it down as a static route.
I’m banging my head against the wall already with this, so please help!
Did you find the solution? I’ve just posted about the same question, missed your post.
I’m having exactly the same problem. Just upgraded to 6.37.2, it did not help.
Nope, no solution yet.
I guess this is the exact scene.
Powerful but strange feature, lack of documentation.
http://forum.mikrotik.com/t/packet-escaping-in-mangle/102890/1
