Need help with standard firewall stuff
I have a MikroTik CCR1009 with 8 ethernet ports + 2 SFP ports.
Ether1 is WAN and Ether8 is LAN.
When I apply rule 13 below everything stops working for the clients inside the LAN.
I can connect to the public IP of Ether1 and connect to the web server at port 5001 without a problem.
My goal is to be able to start a new connection inside my LAN behind Ether8 and being able to surf the web.
I also have a server at IP 10.10.10.5 but that part is working as it should.
The rules is copied from this thread: http://forum.mikrotik.com/t/firewall-rules/69251/1
Here are the firewall rules:
0 ;;; Disallow weird packets
chain=input action=drop connection-state=invalid log=no log-prefix=“”
1 ;;; Allow ICMP Anywhere
chain=input action=accept protocol=icmp log=no log-prefix=“”
2 chain=forward action=accept protocol=tcp dst-address=10.10.10.5 dst-port=80 log=no log-prefix=“”
3 chain=forward action=accept protocol=tcp dst-address=10.10.10.5 dst-port=443 log=no log-prefix=“”
4 chain=forward action=accept protocol=tcp dst-address=10.10.10.5 dst-port=5000 log=no log-prefix=“”
5 chain=forward action=accept protocol=tcp dst-address=10.10.10.5 dst-port=5001 log=no log-prefix=“”
6 ;;; Allow New Connections from LAN to WAN
chain=input action=accept connection-state=new in-interface=ether8 log=no log-prefix=“”
7 ;;; Allow Established Connections from LAN to WAN
chain=input action=accept connection-state=established in-interface=ether8 log=no log-prefix=“”
8 ;;; Allow Related Connections from LAN to WAN
chain=input action=accept connection-state=related in-interface=ether8 log=no log-prefix=“”
9 ;;; Disallow anything from anywhere on any interface
chain=input action=drop in-interface=ether8 log=no log-prefix=“”
10 ;;; Allow New Connections from LAN to WAN
chain=forward action=accept connection-state=new in-interface=ether8 log=no log-prefix=“”
11 ;;; Allow Established Connections from LAN to WAN
chain=forward action=accept connection-state=established in-interface=ether8 log=no log-prefix=“”
12 ;;; Allow Related Connections from LAN to WAN
chain=forward action=accept connection-state=related in-interface=ether8 log=no log-prefix=“”
13 X ;;; CleanUP
chain=forward action=drop log=no log-prefix=“”
Rule with both connection-state=established and in-interface=ether8 allows packets of established connections that come from ether8. Packets, not connections. But packets for established connections need to go both ways. If you enable your rule 13, it makes sure that no connection from LAN can be established.
Solution is to remove in-interface from rules with connection-state=established/related (rules 7, 8, 11, 12). And you probably want to move these rules to top before everything else, since they’re going to be the most used ones.
And rule 9 does not match the description either. It blocks everything from LAN, but nothing will ever hit it, because all packets will be caught by rules 6-8. So it looks like you don’t want in-interface=ether8 there either.
I was looking at the MikroTik forum regarding the firewall queues and noticed this:
  • input > - used to process packets entering the router through one of the interfaces with the destination IP address which is one of the router’s addresses. Packets passing through the router are not processed against the rules of the input chain
  • forward > - used to process packets passing through the router
  • output > - used to process packets originated from the router and leaving it through one of the interfaces. Packets passing through the router are not processed against the rules of the output chain
Link to forum: http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
Since i only uses forward except for rule 0 nothing will block access to the router in any way right?
Thank you for the information regarding the firewall rules.
I’m actually working with firewalls daily but every brand has it’s own way of doing and matching firewall rules.
This is my ruleset today for both IPv4 and IPv6. If something is wrong, please tell me.
This are the rules for IPv4.
0 ;;; Disallow weird packets to router
1 ;;; Allow ICMP anywhere
chain=forward action=accept protocol=icmp log=no log-prefix=“”
2 ;;; Allow new connections from LAN
chain=forward action=accept connection-state=new src-address=10.0.0.0/8
3 ;;; Allow established and related connections from anywhere
chain=forward action=accept connection-state=established,related log=no
log-prefix=“”
4 ;;; Port 5001 to NAS
5 ;;; Port 5000 to NAS
6 ;;; Port 443 to NAS
7 ;;; Port 80 to NAS
8 ;;; Port 6690 to NAS - CloudStation
dst-port=6690 log=no log-prefix=“”
9 ;;; Port 22 to NAS
dst-port=22 log=no log-prefix=“”
10 ;;; Port 21 to NAS
dst-port=21 log=no log-prefix=“”
11 ;;; Port 873 to NAS - Network Backup
dst-port=873 log=no log-prefix=“”
12 ;;; Port 8443 to unify.example.com
chain=forward action=accept protocol=tcp dst-address=10.10.10.14
dst-port=8443 log=no log-prefix=“”
13 ;;; Port 8080 to unify.example.com
dst-port=8080 log=no log-prefix=“”
14 ;;; Clean Up
This are the rules for IPv6.
chain=forward action=drop connection-state=invalid log=no log-prefix=“”
1 ;;; Allow ICMPv6 Anywhere
chain=forward action=accept protocol=icmpv6 log=no log-prefix=“”
chain=forward action=accept src-address=2001:470:28:3b::/64 connection-state=new log=no log-prefix=“”
chain=forward action=accept connection-state=established,related log=no log-prefix=“”
4 ;;; Port 5001 to NAS - DSM
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=5001 log=no log-prefix=“”
5 ;;; Port 5000 to NAS - DSM
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=5000 log=no log-prefix=“”
6 ;;; Port 443 to NAS - DSM
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=443 log=no log-prefix=“”
7 ;;; Port 80 to NAS - DSM
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=80 log=no log-prefix=“”
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=6690 log=no log-prefix=“”
9 ;;; Port 22 to NAS - SSH
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=22 log=no log-prefix=“”
10 ;;; Port 21 to NAS - FTP
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=21 log=no log-prefix=“”
chain=forward action=accept protocol=tcp dst-address=2001:470:28:3b::5/128 dst-port=873 log=no log-prefix=“”
12 ;;; CleanUP
RouterOS firewall is basically Linux iptables, same logic applies. Default policy is set to accept, so unless you block something, it’s allowed.
With your rules, I don’t see anything I’d call wrong, but there’s always something that can be done differently. Based on what I usually do:
  • I would slightly reorder them to have most used first (e.g. established & related #3 is going to be the most used one by far).
  • You might add in-interface= for new connections from LAN, to be absolutely sure that no one can do anything bad from outside, although the possibility of that is more theoretical.
  • In case of IPv4, you could probably replace all specific rules #4-13 for individual ports by just one with connection-nat-state=dstnat (assuming those are port forwards done at this router). On the other hand, counters for individual rules are nice too and if you have only few of them, you don’t need to worry much about optimization.
  • For IPv4, you probably don’t need allow ICMP rule #1. Requests from LAN (and replies) are covered by allow LAN rule #2. And unless you’re part of some larger LAN, you don’t need to allow incoming ones (nobody needs to be able to ping 10.0.0.0/8 from outside). But again, chances of it actually happening are very low.
  • Little filtering of input also doesn’t hurt. Allow established & related, drop invalid, allow icmp, allow ports for services (winbox, ssh, …) you need and from where you need them, drop the rest.
