Part of my job is configuring replacement router for customer. I work from home and my home routeur is a Mikrotik router. In my workflow, I preconfigure routeur to be drop in replacement. If customer router need a static IP, or a PPPoE, my home router act has the “fake” ISP, to allow customer router access to Internet through NAT on my own ISP
Example
My WAN IP: 50.x.x.187/24
My WAN GW: 50.x.x.1/24
Customer WAN IP: 60.x.x.2/30
Customer WAN GW: 60.x.x.1/30
Work great but with limitation. When I configure that “fake” 60.x.x.x/30 subnet on my router, I can not reach old router on that “real” 60.x.x.x/30 because of that “fake” direct connect IP on br-fake-isp-static.
Here come VRF…
Why not having a “lab” VRF where “fake” 60.x.x.x/30 is only valid on “vrf-lab”, not affecting default vrf-main. So I can still reach “real” 60.x.x.x/30
add address=10.100.10.1/24 interface=bridge-lan
add address=50.x.x.187/24 interface=ether1-WAN
add address=60.x.x.1/30 interface=bridge-fake-isp-static
/ip vrf
add interfaces=bridge-fake-isp-dhcp,bridge-fake-isp-static name=vrf-lab
add gateway=50.x.x.1/24
add gateway=50.x.x.1/24@main routing-table=vrf-lab
VRF leak work as expected, ping request is NATed egress, problem is when ping reply get back is properly NATed back to 60.x.x.2 but on VRF-main instead of VRF-lab so it is forwarded to ether-WAN instead of bridge-fake-isp-static back to customer router. Shoud my route leakeage done different ?
[admin@rt101.home.loc] /ip/vrf> /tool/sniffer/quick ip-address=1.1.1.1
Columns: INTERFACE, TIME, NUM, DIR, SRC-MAC, DST-MAC, SRC-ADDRESS, DST-ADDRESS, PROTOCOL, SIZE, CPU
INTERFACE TIME NUM DIR SRC-MAC DST-MAC SRC-ADDRESS DST-ADDRESS PROTOCOL SIZE CPU
bridge-fake-isp-static 2.302 2 <- C8:4F:86:FC:xx:xx C4:AD:34:EA:xx:xx 60.x.x.2 1.1.1.1 ip:icmp 98 0
ether1-WAN 2.303 3 -> C4:AD:34:EA:xx:xx 00:EB:D5:ED:xx:xx 50.x.x.187 1.1.1.1 ip:icmp 98 0
ether1-WAN 2.321 4 <- 00:EB:D5:ED:xx:xx C4:AD:34:EA:xx:xx 1.1.1.1 50.x.x.187 ip:icmp 98 7
ether1-WAN 2.321 5 -> C4:AD:34:EA:xx:xx 00:EB:D5:ED:xx:xx 1.1.1.1 60.x.x.2 ip:icmp 98 7
Any idea how to allow my home network to reach “real” 60.x.x.2/30 but still allow “fake” 60.x.x.2/30 to reach Internet through NAT ? Mangle with route-mark ? Routing rules ?
