Need help
I have some questions regarding starting an ISP business. I’m not very experienced in this field, so I could use some advice.
Can I use the MikroTik hAP ax2 router as my main router to distribute fiber optic connections to around 150+ users?
I also plan to connect an outdoor router to the hAP ax2 and set up a captive portal.
I need full control over internet distribution, similar to an ISP, and I plan to use PPPoE for user routers.
Any guidance would be greatly appreciated.
Thank you!
The ‘h’ in hAP stands for ‘Home’, seems to be the wrong device for your needs.
might get some basics like knowledge on routing, firewalling, what-not and concerns on infrastructure to serve customers first i suggest
