I wonder if someone could help me with the hotspot function in a rb 951 router..
I am running the hotspot function on the bridge 1 with the port eth2 up to wlan,
I did the normal hotspot setup and it works fine, but we now need more than 254 dhcp adresses.
What must I do that we can distribute much more adresses and where do we have to change this?
Thanks in advance for your help
Regards Arthur
You can use another IP address.
Use 172.16.0.1/16 will provide 65534 IP address
hi gustavomam,
thank for your suggestion.
what i did so far now:
in the dhcp server I changed the ip adress into 10.5.50.0/23
So I should have now 512 adresses.
changing it into 10.5.50.0/22 is not possible.
Can anyone tell me why?
Btw.
When I want to change the adresses after a hotspot setup with 10.5.50.0/24 into 172.16.01/16
can I do this in the dhcp server and thats it? should I do the hotspot setup again???
what about the gateway then?
Thanks in advance!
Hi
10.5.50.0/22 is not possible network cause 50 in binary 00110010 is a host address for 3th byte so you can not use as network address.
IP Range 10.5.48.1 - 10.5.51.254 so 10.5.50.0/22 is a IP between range. 1022 host available
10.5.48.1/22 should be the gateway ( IP address on interface)
10.5.50.0/23
10.5.50.1/23 should be the gateway ( IP address on interface)
IP Range 10.5.50.1 - 10.5.51.254. 510 host available
Remember network and IP address are different, you can use http://www.subnet-calculator.com to check IP address/network you would like to use.
Router expect IP address in a interface with format 10.5.0.1/16 and automatically knows belong to 10.5.0.0/16 network if you donβt specify
My advice is with the new IP address, make hotspot setup again because you will need a new pool, new DHCP server, etc etc in order to your hotspot work properly.
Regards.
Hi gustavomum,
thanks for your reply.
Is it possible, that you can give me an Example, when making a hotspot setup
1 Local Adress of network should be?
2 Adress pool of Network?
What adresses should I use that I can distribute about 10.000 Adresses?
Regards
kupfistanton
Rather than making your subnet larger to allow so many addresses which would cause you a huge amount of issues why dont you reduce your lease time. There is no way you will have 254 concurrent connections. If you look at the maximum amount of time a client may stay connected for and adjust your lease time this should resolve your issue. Having a massive broadcast domain is a big no no try stick to 512 or under otherwise you will start to affect performance.
My Problem ist that we are running a hotel with more than 200 beds.
Nowadays lot of people show up with more than 2 devices.
All customers should login with the same login and password anyway, and they should stay in without having to login again.
I thought enlarging the dhcp pool might be the easiest I can do.
At the moment everything runs ok, but one issue.
Altough I use mac-cockie (3days), the clients still get kicked out and they have to relogin again
Does anyone know why this can happen?
Regards Arthur
