Need other 10.X.X.X routers to route out
Hi all, I have a Powerbox router that is connected to a modem on eth1, has a backhaul connection to other networking gear on eth2 as well as an AP on eth3. OSPF seems to be working correctly, and connections that originate from the Mikrotik router seem to work, but i can’t seem to get traffic from anything of the other 10.X.X.X gear to route out the Powerbox router. Traceroute stops at the Mikrotik router but goes no further. If it helps there are two virtual mikrotik routers in a datacenter that are my route out via L2TP connections. Any ideas?
# sep/07/2023 21:46:58 by RouterOS 6.49.10
# software id = WUCQ-M8Q6
# model = 960PGS
# serial number = ABCDEFGHIJKL
set [ find default-name=ether1 ] mac-address=64:D1:54:24:2A:07 name=e1-Modem \
    speed=100Mbps
set [ find default-name=ether2 ] mac-address=64:D1:54:24:2A:08 name=\
    e2-GoNav-AP poe-out=forced-on speed=100Mbps
set [ find default-name=ether3 ] mac-address=64:D1:54:24:2A:09 name=\
    e3-GoNav-BH-GO2 poe-out=forced-on speed=100Mbps
set [ find default-name=ether4 ] mac-address=64:D1:54:24:2A:0A name=e4 speed=\
    100Mbps
set [ find default-name=ether5 ] mac-address=64:D1:54:24:2A:0B name=e5 speed=\
    100Mbps
set [ find default-name=sfp1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=\
    64:D1:54:24:2A:0C
/interface l2tp-client
add connect-to=50.7.X.X disabled=no max-mru=1460 max-mtu=1460 name=\
    l2tp-fdc1 password=subersecret user=go-nav
add connect-to=107.181.X.X disabled=no max-mru=1460 max-mtu=1460 name=\
    l2tp-stam1 password=subersecret user=go-nav
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=dhcp_pool2 ranges=10.199.197.200-10.199.197.254
add name=dhcp_pool3 ranges=10.199.198.200-10.199.198.254
add address-pool=dhcp_pool2 disabled=no interface=e3-GoNav-BH-GO2 name=dhcp1
add address-pool=dhcp_pool3 disabled=no interface=e2-GoNav-AP name=dhcp2
/routing ospf area
add area-id=0.0.0.1 name=morongo
/routing ospf instance
set [ find default=yes ] router-id=10.199.198.1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
set discover-interface-list=discover
add interface=e2-GoNav-AP list=discover
add interface=e3-GoNav-BH-GO2 list=discover
add interface=e4 list=discover
add interface=e5 list=discover
add interface=sfp1 list=discover
add list=discover
add list=mactel
add list=mac-winbox
add address=10.199.197.1/24 interface=e3-GoNav-BH-GO2 network=10.199.197.0
add address=10.199.198.1/24 interface=e2-GoNav-AP network=10.199.198.0
/ip dhcp-client
add add-default-route=no disabled=no interface=e1-Modem use-peer-dns=no \
    use-peer-ntp=no
add address=10.199.197.0/24 dns-server=10.199.198.1 gateway=10.199.197.1
add address=10.199.198.0/24 dns-server=10.199.198.1 gateway=10.199.198.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add distance=1 gateway=66.74.56.1
add check-gateway=ping distance=1 dst-address=8.8.8.8/32 gateway=10.106.8.217
add distance=1 dst-address=50.7.X.X/32 gateway=66.74.X.X
add distance=1 dst-address=72.8.X.X/32 gateway=66.74.X.X
add distance=1 dst-address=107.181.X.X/32 gateway=66.74.X.X
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=both
/routing ospf interface
add cost=54 network-type=broadcast
add cost=54 interface=l2tp-fdc1 network-type=point-to-point
add cost=54 interface=l2tp-stam1 network-type=point-to-point
/routing ospf network
add area=morongo network=10.199.198.0/24
add area=morongo network=10.199.197.0/24
add area=morongo network=10.106.8.217/32
add area=morongo network=10.106.5.217/32
add area=backbone network=10.106.5.17/32
add area=backbone network=10.199.193.0/24
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name="GoNav NEW"
/system ntp client
set enabled=yes primary-ntp=66.220.10.2 secondary-ntp=45.55.58.103
/system watchdog
set ping-start-after-boot=15m ping-timeout=10m watch-address=8.8.8.8
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
The Powerbox had a previous configuration on it, so i cleared the firewall using this command
/ip firewall filter remove [/ip firewall filter find]
Well apparently i didn’t think to put the srcnat masquerade rule back in. As soon as I did the traffic started flowing again.
Thanks for looking, and thank you Gustavo!
https://fiverr.com/s/2oGmKQ
