need to configure mikrotik as a managable switch
this my diagram i am a internet service provider in my town.i have 500 Mbps with 8 IP pool Cir and want to share with my three loop holder, first one require 70 Mbps, second require 20 Mbps and third require 35 Mbps and rest for my usage.i want to give them live ip (public ip ) i want to configure a mikrotik as a manageable switch .how to bound the ports which they pass the my live ip to my loop holder? i have try my best to do so but not succeeded. i want to configure ingress and egress rate in mikrotik ports to pass the live ip with bound speed
You are the author of this post http://forum.mikrotik.com/t/mikrotik-as-a-manageable-switch/128238/9 and this too http://forum.mikrotik.com/t/mikrotik-as-a-manageable-switch/130244/1 , off which all is about the same request.
If you still can’t do it after some of the responses from the above posts, you may consider
to hire a consultant to set up the network for you. It may be expensive at the start but the long term it is going to cheaper, less time consuming, and avoid possible problems for customers, in summary, good for your business.
