Can you believe this guy, He gets FREE ADVICE and he complains, I bet if he was paying “professional fees” he wouldn’t complain but be thankful?, comments like his are totally counter-productive, it would be much easier to just read the posts and make notes do they apply to your config/network, not reply but let someone else reply, which leads me to my next comment a system should be in place where all of 19575 users should have a minimum activity over a 1 year period, all to often we see forums been used to address a issue(s) when done leave without even thanking or updating if the advice posted worked or not?
thank u 4 ur help and thanks 4 making fun of me,i dont know what is ccq (i said am new to this).i google it and now i know
Ok - Can i ask some more questions so we can help,
(1) Are you sure you only have 256Kb for 35 users, If so low CCQ and signal will be the least of your troubles as you will have a lot of unhappy clients? (I am not making fun of you but pointing out a reality )
(2) Your signal has gone from -54 to -69, this is really a process of elimination to track down the cause,
(3) I will ask as you were not familiar with CCQ are you sure the AP frequency was not changed,
(4) Have you checked the alignment of both dish’s, (to test manually press on dish and monitor signal levels)
(5) If this is not the cause, then try radio-card(s) lead from router to antenna,
hi again
1)no u miss understood me , i meant 256Kb for each user ,so i asked is there will be a problem transmitting all that bandwidth,is there?
2) no it ddin.t changed
3)i think thats my problem but i cant be in touch with the other piece coz its on a 40 M tower (my ISP uses towers to transmit internet wirelessly),does it work if i test my signal with my piece even if the other is the 1 that moved ?
there might be some changes in LOS from ur site. or some new tower coming up nearby. Transmitting that much bandwidth should not be an issue . try using freq. 5700-5800. Should help
