it is possibile config Mikrotik Ax3 v7.7 to put only Netflix traffic over Tailscale ?
How to do that ?
Tailscale wan’t to start on Container ![]()
How to fix it ?
How to do that ?
How to fix it ?
Any neu possibility to run tailscale on mikrotik router?
Maybe is related to this similar issue: https://github.com/containers/podman/issues/17016
Try to set PATH env. variable for this container with value: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Unfortunately not on native RoS, but you might try ZeroTier that is similar to TailScale.
path issues should be fixed in latest beta versions
