I have an RB3011 UiAS-RM cannot get a successfull netinstall to work.
RouterOS is 6.49.11 and is working on this unit.
The router works, I am able to upgrade/change firmware via the files functionality.
I cannot get the router to perform a netinstall.
I’m very familiar with the process and how it should work.
I can also netinstall witouth any problems on other RB3011 routers they work.
Do I have a bad router? corrupt or not working bootloader?
And is there any way to fix this?
I’m really puzzled and stuck on this one and I have tried a lot of things..
Updating the routeros via files, upgrading routerboot via winbox etc.
I seem to be able to update the router just fine this way. but cannot get a successful netinstall for any versiopn of routeros/netinstall.
I DO want to format/wipe the filesystem.
If I try to netinstall 6.49.11 it says “Installing” for about 5 seconds then switches to “READY” it never formats the drive or installs routeros.
If I try to netinstall 7.18.2 (using 7.18.2 netinstall software) it does TFTP transfer at the beginning and fails with “malformed packet” and the router never “shows up” in netinstall.
7.18.2 netinstall:
No. Time Source Destination Protocol Length Info
52063 925.877110 10.73.73.3 10.73.73.99 TFTP 60 Acknowledgement, Block: 2794
52064 925.877123 10.73.73.99 10.73.73.3 TFTP 1498 Data Packet, Block: 2795
52065 925.877863 10.73.73.3 10.73.73.99 TFTP 60 Acknowledgement, Block: 2795
52066 925.877876 10.73.73.99 10.73.73.3 TFTP 1498 Data Packet, Block: 2796
52067 925.878565 10.73.73.3 10.73.73.99 TFTP 60 Acknowledgement, Block: 2796
52068 925.878591 10.73.73.99 10.73.73.3 TFTP 1498 Data Packet, Block: 2797
52069 925.879239 10.73.73.3 10.73.73.99 TFTP 60 Acknowledgement, Block: 2797
52070 925.879251 10.73.73.99 10.73.73.3 TFTP 330 Data Packet, Block: 2798 (last)
52071 925.879494 10.73.73.3 10.73.73.99 TFTP 60 Acknowledgement, Block: 2798
52072 925.879571 10.73.73.99 10.73.73.3 BOOTP 46 Unknown BOOTP message type (112)[Malformed Packet]
52073 926.436643 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
52074 926.468835 10.73.73.99 10.73.73.3 UDP 46 5000 → 5001 Len=4[Malformed Packet]
6.49.11 netinstall
7.1 Fail exits etherboot and boots OS
Try to install Routeros 6.49.11 (using netinstall 6.49.11 netinstall software)
Click "Install"
Says "INSTALLING" for 5 seconds then switches to "READY"
Never completes.
Small packet flow forever:
UDP 197 5000 → 5000 Len=155
About two packets per second.
Netinstall never happens
I tried a number of other things (different routeros) different versions of netinstall etc.
And get similar (but different results) and netinstall not working for this unit.
Trying to keep this initial post short as possible and not including all of the other things that I tried that also did not work.
Looking for help and any other things I might try.
7.18.2 netinstall attempt: (router never shows up)
Router does show up
Click "Install"
Never completes.
7867 67.624170 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7868 68.495311 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
7869 68.625474 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7870 69.500095 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
7871 69.626489 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7872 70.500616 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
7873 70.627937 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7874 71.495265 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
7875 71.629074 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7876 72.499828 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.31? Tell 10.73.73.99
7877 72.630377 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7878 73.004844 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.1? Tell 10.73.73.99
7879 73.631555 0.0.0.0 255.255.255.255 UDP 197 5000 → 5000 Len=155
7880 73.998166 ASUSTekCOMPU_09:b8:5e Broadcast ARP 42 Who has 10.73.73.1? Tell 10.73.73.99
7.1 netinstall attempt:
Router never shows up:
etherboot exits and roots routerOS on it's own soon after netinstall for 7.1 is ran.
