netinstall problem
Hi i have a rb1000. it could not boot properly so i decided to do netinstall. i set all parameters right but netinstall couldn’t detect my router. i set net boot IP to 192.168.1.2 and my pc to 192.168.1.5. see the image bellow.
kindly help.
thanks
Have you click anny key in this 2 seconds?
Than can you force the netbooting and can you start netinstall.
yes i pressed any key and then went to menu, then boot option then boot over ethernet.
Have you disabled the firewall on your pc or laptop?
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
thanks alot, i just turned off windows firewall and all worked fine. thanks again.
Ok great!! if you want give me karma pleace :slight_smile:
