Netinstall -PXE issues
Long story short - I have an RB 112, bootload 2.18 - and have unfortunately reset the whole thing after a failed upgrade to 3.28.
I’m trying to use NetInstall as per the Wiki, but it isn’t seeing my Altiris PXE server, so NetInstall doesn’t see it.
I am getting the following:
Press any key within 9 seconds to enter setup…
kernel not found
trying dhcp protocol… OK
failed to resolve mac address
kernel loading failed
Is there a particular port that it needs to bind to? Have I overlooked something in the PXE setup?
Altiris is running on Windows Server 2008R2, DHCP is running and I have FreeDos as the PXE image to push out, using DHCP option 60
Should I try bootp? Are there any good guides for bootp?
