Hello, i just installed a 52 km long ptp link with 2 Netmetal AX. I used high quality Radiowaves antennas with 31dB of gain. The line of sight is clear. I already have dozen of links of about 70km with Netmetal AC, 5SHP and they all works fine.
With the new Netmetal AX, it seems that links longer than 30km are not possible to establish.
Can you help me on that?
