netPower Lite 8P Crashing on Stats tab
I recently purchased a netPower Lite 8P (CSS610-8P-2S+OUT) switch. It works generally well, but I find a strange issue: Whenever I go to the Stats tab, the device crashes, a manual power reset (reboot) does not bring it back to life and only a reset helps (the blue Power LED is on, the green DC in LED is on, but all the Link/Act LEDs of Ethernet and SFP stay off). My setup is fairly simple:
  • 1x SFP port in use as uplink, trunk
  • 2x ethernet ports connected to clients without POE, each in one VLAN (enforced by the switch)
  • Manual 28V power supply from a lab power supply (stable and reliable)
  • SwOS lite version 2.21 (should be the most recent)
  • Admin Password set
As we plan to install it on a remote site, a firmware issue like this would be a no go for us. Is this issue known?
Thanks a lot for any help,
Chris
I already found a lot of software glitches on this device. But not this one. Please send this on Mikrotik support.
Thanks for the fast reply. Will do.
Mine has been rock solid on that firmware, fwiw . . . 2x SFP in use (1 DAC, 1 Optic), 3 ports POE to CAP AX AP's, and 4 other ports used non-poe. 5 VLANs configured.
Can you try to unplug the SFP module and check whether the crashing occurs or not?
I will try that when I'm back at the device location. The SFP module is a Mikrotik S-31DLC20D. I already tried swapping it for another one from a different manufacturer, but same issue.
Chris
Quick update: Today, I tried what you suggested and alas the crash did not occur with the SFP module unplugged. Still, I use Mikrotik SFP modules so this should not be an issue.
I also added this to the support ticket, let's see...
Chris
Please include in your ticket the exact SFP module type and version, too, this information is also important.
I'd suggest the larger CRS318-16P - runs RouterOS, and has been very stable for me in a fairly complex HW offloaded VLAN setup (two such devices on a 12m high mast with many different radios, lots of aging outdoor cat5e replaced with much cleaner DC power + fiber). CSS devices are a bit cheaper, but SwOS Lite has limited features and very little maintenance.
FWIW, the CSS318 is full SwOs, the CSS610 is SwOs Lite (and not sure what else).
Update: The problem seems to occur now also after few hours of operation without any intervention on the web interface. Connections drop and configuration is lost completely. To be honest, I did not expect such issues on SwOS (Lite) considering the reliability of RouterOS.
@marekm Yes, considering all this I will go for the CRS318-16P instead or even the RB960PGS-PB as this should be enough for the application and the CRS318-16P seems a bit of an overkill.
Chris
In most cases it does not matter if it runs the SwOS or Lite. You can find the differences here: SwitchOS Lite vs. SwOS - #8 by holvoetn
